I recently upgraded my installation from 3.2.1 to 4.2.0. On my old installation, the check_snmp plugin worked fine. I defined a separate command to use version 2 (but still using the same script), and now all of a sudden after the upgrade, the version 2 checks don't work. if I manually execute the script, I get the following:
./check_snmp -H <IP Address> -P 2c -C Public123$ -o 1.3.6.1.4.1.9.2.1.8.0
SNMP OK - 81118420 | 1.3.6.1.4.1.9.2.1.8.0=81118420
Command Definition:
command_name check_snmpv2
command_line $USER1$/check_snmp -P2c -H $HOSTADDRESS$ -C $ARG1$
Service Definition:
host_name <Hostname>
service_description Memory Usage
check_command check_snmpv2!Public123$ -o 1.3.6.1.4.1.9.2.1.8.0
servicegroups snmp
I can't figure out why this wouldn't work, especially considering that it worked fine on the old installation.
I'd appreciate any help you guys can give me.
