I need to monitor the tipping point network device from nagios by using the O.I.D. Could you, Please help how to configuring the severity of the attack in the nagios.
objectname: tptSystemLogNotifySeverity
O.I.D: 1.3.6.1.4.1.10734.3.3.3.1.94.0
The severity of the attack: • 1: critical
• 2: error
• 4: warning
nagios@boxer/usr/local/nagios/libexec> ./check_snmp -H x.x.x.x -C GTIPSrk -o 1.3.6.1.4.1.10734.3.3.3.1.94.0
SNMP OK - 0 | iso.3.6.1.4.1.10734.3.3.3.1.94.0=0
You have new mail in /var/spool/mail/nagios
nagios@boxer /usr/local/nagios/libexec>
montoring of the network device
Re: montoring of the network device
Are you just asking how to configure the host and service for that check? It looks like you have the plugin syntax figured out already.
Have you looked at our Object Definition documentation?
It has all of the options you can use for hosts, services, contacts, or anything else in Nagios. Give that a read and if you have specific questions please report back and we'll see what we can do.
sunnynani4849
Hi donald,
Thanks for the reply.
Do you have any further questions or are we good to mark this as resolved?
