Nagios and Offset value in host check
zahid72
Post by zahid72 »
Hi All,
I am running Nagios for past 5 years with all good efforts. New codes / plugins developed in response to Ops demand. I have configured check_ping for multiple hosts through hostgroup_name owing to a comfort in configuration. But when this is run, it forks all in one time, exerting load on machine which sometimes yields in high CPU / uptime outputs. I have recently configured smokeping and one of its interesting point is its offset value to run the service at random time.
My question: is there any option of offset value in check_ping or check_icmp in order to execute the multiple ping process at random intervals.
Thanks in advance
Re: Nagios and Offset value in host check
Post by Box293 »
What version of Nagios are you using? Nagios Core 4.x has this functionality built in and has added workers which helps in these scenarios.
