Nagios BPI send notifications
Rafdek
Post by Rafdek »
Hello team
Configure Nagios BPI on my server Nagios Core, I have already set up a service group and everything works great.
I just need to send me notification the change of status service group, through mail and run a script developed by me.
Where I set these parameters in Nagios BPI .
Any idea ?
Regards
Re: Nagios BPI send notifications
You could add a BPI group as a service check to a "dummy host", and enable notifications on it. Please, review our "Nagios - Using The BPI Addon" document here:
https://assets.nagios.com/downloads/nag ... _Addon.pdf
Note: Check the "BPI Checks with Nagios Core" section on the bottom. Hope this helps.
Rafdek
Post by Rafdek »
Tnks lmiltchev
I created the host using the check_dummy and Service check_bpi
Other configurations are the same as those of a single host.
without forgetting to declare the command check_dummy in the file commands.cfg
Regards
Thanks for the feedback, Rafdek! Let us know if it is safe to close this thread.
