how can solve Socket timeout problem
baber
Post by baber »
dear all
Hi
i have a windows server but sometimes 1 or 2 sensors show this message in nagios server (CRITICAL - Socket timeout after 10 seconds)
but other services are ok and this message usaually appear every 10min and after that is ok
how can solve this problem ?
please see attach pic in first time pic1 show and after few minutes pic2 appear and all is ok but after few minutes again appear pic1
this problem just appear for 2 or 3 servers of 110 server
what is problem?
Re: how can solve Socket timeout problem
Post by mcapra »
If this is using check_nt, you could try altering your Service/Command definitions to have a higher timeout threshold. Something like -t 30 might be sufficient.
If you're not sure how to go about that, can you show us the associated Service and Command definitions that are having problems?
baber
Post by baber »
mcapra wrote:If this is using check_nt, you could try altering your Service/Command definitions to have a higher timeout threshold. Something like -t 30 might be sufficient.
I used -t 240 but for that sensor show this message
connect to address x.x.x.x and port 12489: Connection timed out
Can you attach the nsclient.log file from the client machine, and also show us your entire service definition?
baber
Post by baber »
rkennedy wrote:Can you attach the nsclient.log file from the client machine, and also show us your entire service definition?
atach critical error appear
and i have attached nsclient.log and server.cfg file
	use		windows-server	; Inherit default values from a template
	host_name	onlinecard_cdc1	; The name we're giving to this host
	alias		server onlinecard_cdc1	; A longer name associated with the host
	address		x.x.x.x		; IP address of the host
	use			local-service
	service_description	Memory Usage
	check_command		check_nt!MEMUSE!-w 90 -c 95
	use			local-service
	service_description	 Service
	check_command		check_nt!SERVICESTATE!-d SHOWALL -l SNMP -t 240
	use			local-service
	service_description	Cpu Usage
	check_command		check_nrpe!alias_cpu
	use			local-service
	service_description	Disk Space
	check_command		check_nrpe!alias_volumes
	use			local-service
	service_description	Time
	check_command		check_nrpe!check_windows_time
        service_description     Uptime
        check_command           check_nt!UPTIME -t 180
        service_description     CPU Load
        check_command           check_nt!CPULOAD!-l 5,80,90
-t is not useful because i used that for Service but after a few minutes show this error
nsclient.log
(2.37 KiB) Downloaded 368 times
nsclient.ini
(15.48 KiB) Downloaded 337 times
It looks like some of your checks that aren't failing are using NRPE, but the failing ones are using check_nt. Is anything blocking traffic on port 12489 periodically?
baber
Post by baber »
rkennedy wrote:It looks like some of your checks that aren't failing are using NRPE, but the failing ones are using check_nt. Is anything blocking traffic on port 12489 periodically?
all ports on my servers are open my servers has full port access i am realy confused
From the command line of Nagios, please run the following commands and post back the full output (install nmap if you do not have it already) -
nmap x.x.x.x -p 12489
nmap x.x.x.x
(replace x.x.x.x with the IP of the Windows machine we're troubleshooting here.)
baber
Post by baber »
rkennedy wrote:From the command line of Nagios, please run the following commands and post back the full output (install nmap if you do not have it already) -
nmap x.x.x.x
nmap 10.4.1.144 -p 12489
Starting Nmap 5.21 ( http://nmap.org ) at 2016-08-18 00:08 IRDT
mass_dns: warning: Unable to determine any DNS servers. Reverse DNS is disabled. Try using --system-dns or specify valid servers with --dns-servers
Nmap scan report for 10.4.1.144
Host is up (0.00085s latency).
PORT      STATE    SERVICE
12489/tcp filtered unknown
Nmap done: 1 IP address (1 host up) scanned in 0.35 seconds
nmap 10.0.4.123 -p 12489
Starting Nmap 5.21 ( http://nmap.org ) at 2016-08-18 00:11 IRDT
Nmap scan report for 10.0.4.123
Host is up (0.00082s latency).
PORT      STATE SERVICE
12489/tcp open  unknown
MAC Address: 00:0C:29:4A:E1:B0 (VMware)
Nmap done: 1 IP address (1 host up) scanned in 0.17 seconds
 nmap 10.0.4.119 -p 12489
Starting Nmap 5.21 ( http://nmap.org ) at 2016-08-18 00:13 IRDT
Nmap scan report for 10.0.4.119
Host is up (0.0015s latency).
PORT      STATE SERVICE
MAC Address: 00:50:56:86:28:0D (VMware)
For the record, which machine are we troubleshooting? It looks like you posted 3 separate nmap's.
