cp: cannot stat `command.cfg': No such file or directory
kaushalshriyan
Post by kaushalshriyan »
I am facing the issue cp: cannot stat `command.cfg': No such file or directory when i run rpmbuild-ba nagios-plugins.spec -> http://sprunge.us/eiKe
cat nagios-plugins.spec -> http://sprunge.us/cTCG
cat /etc/redhat-release
CentOS release 6.7 (Final)
Nagios plugin version -> nagios-plugins-2.1.2.tar.gz
Any help will be highly appreciable.
Regards,
Kaushal
bwallace
Re: cp: cannot stat `command.cfg': No such file or directory
Post by bwallace »
This thread looks related:
https://support.nagios.com/forum/viewto ... 35&t=27761
Have you attempted to run through the steps mentioned there?
jfrickson
Post by jfrickson »
The file 'command.cfg' has not been in plugins since version 1.5 back in 2013.
I've fixed the spec file in the 'maint' branch. The fix will be in the next release.
