i have check_odbc plugin was ruuning on server perfect. we formatted the server and install windows 2012 and i install nsclient on server to reactive check_odbc, but when i run the command i see the below error.
SQL CRITICAL - can't open db (###).
what is wrong or what is missing?
Thank you.
Check_odbc plugin
murawweh.daher
Check_odbc plugin
Regards,
Murawweh Daher
Murawweh Daher
Re: Check_odbc plugin
I'm not a Windows guy, but if you reformatted and reinstalled Win2k12 would you not also need to reconfigure ODBC?
murawweh.daher
i didn't reconfig the ODBC, i will try today and update.
Regards,
Murawweh Daher
Murawweh Daher
Please let us know if you are still running into issues afterward.
murawweh.daher
i solved this case after configure the ODBC in windows server.
Thank you for helping
Regards,
Murawweh Daher
Murawweh Daher
Thanks for that update. I'll go ahead and lock this thread but feel free to open a new one for any other issues.
