Export list of working hosts
peterj1974
Post by peterj1974 »
Hi
I'm in the process of bulk uploaded a few thousand new clients into our NagiosXI servers.
I'm expecteding some of these to fail due to firewall rules etc. It's would be easier and quicker for me to upload all of these to Nagios, and then look at the ones that are not connecting.
Is there a way to export a list of working/or non working clients from NagiosXI? Or even a command I can run/file I can grep?
Pete
bwallace
Re: Export list of working hosts
Post by bwallace »
Sure, you can use the 'original' backend API or the REST API (as of Nagios XI 5) to obtain these details
https://support.nagios.com/kb/article.php?id=176
You can also refer to nagios.log:
/usr/local/nagios/var/nagios.log
The Nagios Core log, includes checks, notifications, external commands, and events. This file is rotated daily into the
/usr/local/nagios/var/archives folder (default setting in nagios.cfg) by rsyslog
https://assets.nagios.com/downloads/nag ... ptions.pdf
