I have to rerun the below chown command every time whenever i have to restart the nagios service
chown nagios:nagcmd /usr/local/nagios/var/rw
chown nagios:nagcmd /usr/local/nagios/var/rw/nagios.cmd
systemctl restart nagios.service
cat /etc/redhat-release
CentOS Linux release 7.2.1511 (Core)
Nagios Core 4.2.0
Last Modified: 08-01-2016
License: GPL
Any help will be highly appreciable.
Regards,
Kaushal
rerun chown nagios:nagcmd /usr/local/nagios/var/rw command
kaushalshriyan
Re: rerun chown nagios:nagcmd /usr/local/nagios/var/rw comma
Can you post the instructions you used when initially installing? It looks like the variables for permissions are getting set on start.
What are they getting set to after you start the service? (before running the chown)
kaushalshriyan
Hi Robert,
cat /etc/init.d/nagios -> http://sprunge.us/dJSU. I am following http://tecadmin.net/install-nagios-core ... ntos-rhel/. Please correct me if i am doing wrong.
Regards,
Kaushal
Regards,
Kaushal
If you do restart the nagios daemon, what do the permissions change to?
Can you run the following and post the output?
chage -l nagios
grep nag /etc/passwd
grep nag /etc/groupBe sure to check out our Knowledgebase for helpful articles and solutions!
Also, can you show us the results of
We want to make sure you have the group sticky bit on the directory and the group should be nagios
Additionally your nagios user should be a member of the nagios and nagcmd group
ls -ld /usr/local/nagios/var/rwCode: Select all
drwxrwsr-x 2 nagios nagios 4096 Aug 16 05:59 /usr/local/nagios/var/rwCode: Select all
# cat /etc/group|grep nag
nagios:x:500:nagios,apache
nagcmd:x:501:nagios,apache-
kaushalshriyan
[root@e2e-13-130 nagios]# ls -ld /usr/local/nagios/var/rw
drwxrwsr-x. 2 nagios nagios 4096 Aug 17 08:04 /usr/local/nagios/var/rw
[root@e2e-13-130 nagios]# chage -l nagios
Last password change : Aug 03, 2016
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
[root@e2e-13-130 nagios]# grep nag /etc/passwd
systemd-network
997:996:systemd Network Management:/:/sbin/nologin
nagios
1000
:/home/nagios:/bin/bash
[root@e2e-13-130 nagios]# grep nag /etc/group
nagios
1000:nagios,apache
nagcmd
1001:apache,nagios
[root@e2e-13-130 nagios]# cat /etc/group|grep nag
nagios
1000:nagios,apache
nagcmd
1001:apache,nagios
systemd-network
nagios
nagios
nagcmd
nagios
nagcmd
When you compiled Core, did you run the configure command like below?
Try and recompiling Core by following this guide and see if that fixes the issue.
https://assets.nagios.com/downloads/nag ... Source.pdf
Is selinux enabled on your server? Run the following command and post the output to see if it is enabled.
./configure --with-command-group=nagcmdhttps://assets.nagios.com/downloads/nag ... Source.pdf
getenforceBe sure to check out our Knowledgebase for helpful articles and solutions!
