Hi, I have this idea/problem: I need to run scripts from the Nagios web UI; these scripts should be able to be anything, like turning on a KVM machine.
E.g. I have a dormant developer machine and I need to turn it on (ie virsh start dev-machine) or I have an Ansible playbook and I want to run it.
I know that Nagios is not really supposed to be used like this, but still, if there was a solution I'd be happy to hear it.
Run arbitrary scripts/commands from web UI
Re: Run arbitrary scripts/commands from web UI
If you were using XI you could possibly use something like this:
But in Core I don't believe there is anything that will do what you need from the UI. You can get somewhat close with event handlers and passive services, but that's quite the workaround.
