AD Service Check to monitor status for user state
gselvakumar
Hi Team,
We want implement AD Service Check to monitor status(whether locked) for a particular users on a windows server. Domain level monitoring would what we needed. However, monitoring on the register level would be really awesome if we could, just would be very involved I guess since we would want to monitor other things.
I searched In the forum I got the two urls mentioned below. But I am not sure how to use it for a particular user. Please help me with this requirement.
1) https://exchange.nagios.org/directory/P ... ts/details
2)https://exchange.nagios.org/directory/P ... ck/details
Thanks & Regards,
Gomathyshankar Selvakumar
Re: AD Service Check to monitor status for user state
The Exchange page provides quite a bit of information. An example on how to use it for you would be -
It also mentions what needs to be done, for installing -
You might be able to specify the exact path for the users object, but otherwise I don't see a built in way to specify a certain user. They would need to be in a specific OU. Granted, you could always modify the Powershell script to your needs.
.\lotp_check_ad_accounts.ps1 LockedOut "dc=mydomain,dc=com" subtree 5 10
CRITICAL: 216 LockedOut|216;5;10
-Add a new command:
$USER1$/check_nrpe -H $HOSTADDRESS$ -n -c check_ad_account -a $ARG1$ "$ARG2$" $ARG3$ $ARG4$ $ARG5$
-Add to nsclient.ini:
check_ad_account=lotp_check_ad_accounts.ps1 $ARG1$ $ARG2$ $ARG3$ $ARG4$ $ARG5$
gselvakumar
how to use it for a particular user?
Thanks & Regards,
gselvakumar
Hi
I added below the script in Windows server in the folder C:Program Files\NSClient++\scripts
and added the below mentioned command to nsclient.ini
After that I tried executing below mentioned command from my Nagios console.I am getting an error as mentioned in the attachment.
Please let me know is that anything that I missing?
Please help me with this.
./check_nrpe -H WUSRCDNAG00 -n -c check_ad_account -a AccountInactive "dc=pmside,dc=net" subtree 5 10
Thanks & Regards,
Regarding "CHECK_NRPE: Received 0 Bytes From Daemon. Check The Remote Server Logs For Error
Messages" -- See section V of this doc:
https://assets.nagios.com/downloads/nag ... utions.pdf
If NRPE is running on the client server then the likely problem is the check command does not align with what is specified in the script. Post both items here if the steps in the doc do not enable you to resolve, thanks.
gselvakumar
Is there any other scripts/ways to status for user state apart from one mentioned below
Is there any other method/script that we can use to monitor status for a particular user on a register level rather than on a domain level.
Thanks & Regards,
What do you mean by a 'register' level?gselvakumar wrote:Is there any other scripts/ways to status for user state apart from one mentioned below
For other plugins, search through our Exchange @ https://exchange.nagios.org
gselvakumar
Register level means on local server machines.I need monitor on local windows server machines rather than on the domain controller.Is there any plugin that we can use.
Thanks & Regards,
I don't think so, since user information is generally stored at a domain level. What information are you looking to get exactly? If an account is locked out?
