Dashboard/report for multiple servers CPU and Memory usage
peterj1974
Post by peterj1974 »
Hi
I've created simple dashboard showing graphs of CPU and Memory usage for a single server. I'd now like to get multiple servers into the dashboard showing the same graphs. I can do this by manually adding each server in but is there a quicker way I can do this by passing a list of server names?
Pete
Re: Dashboard/report for multiple servers CPU and Memory usa
At this time there is not, it would need to be done manually.
One thing that might help you, is that you could aggregate multiple graphs in to one using the Home -> Graph Explorer -> Multistacked Performance Graph part of XI. It will let you add multiple hosts / services to the same graph, which you can then add to a dashboard.
peterj1974
Thanks for the reply.
Is it possible to do this via reports?
Pete
Post by mcapra »
At this time, we don't really have a "utilization" report. Other users have requested this though and a feature request is in the queue (ID 9268).
