lost all sources and source groups after 2.2.3 update
djcomber
Post by djcomber »
following a update to 2.2.3 I no longer have any sources showing, it's like a blank slate
Re: lost all sources and source groups after 2.2.3 update
Post by Box293 »
What is the output of:
tail /var/log/messages
tail /var/log/httpd/error_log
ps -ef | grep flow
djcomber
Post by djcomber »
[root@sucgrdc01net01 ~]# tail /var/log/messages
Aug 19 15:10:00 sucgrdc01net01 nfcapd[1453]: laucher waiting childs done. 0 childs
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1471]: Ident: '7' Flows: 29, Packets: 8786, Bytes: 2466728, Sequence Errors: 0, Bad Packets: 0
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1471]: Signal launcher
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1471]: Total ignored packets: 0
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1472]: Run expire on '/usr/local/nagiosna/var/FPCSADSLRouter/flows'
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1472]: Limits: Filesize <none>, Lifetime 2419200 = 4.0 weeks, Watermark: 95%
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1472]: Current size: 31842304 = 30.4 MB, Current lifetime: 2304300 = 3.8 weeks, Number of files: 7675
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1472]: expire completed - nothing to expire.
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1472]: laucher child exit 1 childs.
Aug 19 15:10:10 sucgrdc01net01 nfcapd[1472]: laucher waiting childs done. 0 childs
[root@sucgrdc01net01 ~]# tail /var/log/httpd/error_log
[Fri Aug 19 09:19:47 2016] [notice] caught SIGTERM, shutting down
[Fri Aug 19 09:19:47 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Aug 19 09:19:47 2016] [notice] Digest: generating secret for digest authentication ...
[Fri Aug 19 09:19:47 2016] [notice] Digest: done
[Fri Aug 19 09:19:47 2016] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Fri Aug 19 09:36:52 2016] [notice] caught SIGTERM, shutting down
[Fri Aug 19 09:37:16 2016] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Aug 19 09:37:16 2016] [notice] Digest: generating secret for digest authentication ...
[Fri Aug 19 09:37:16 2016] [notice] Digest: done
[Fri Aug 19 09:37:17 2016] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
nna       1452     1  0 09:37 ?        00:00:02 /usr/local/bin/nfcapd -I 4 -l /usr/local/nagiosna/var/FPCSFibreRouter/flows -p 9912 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/FPCSFibreRouter/9912.pid -D -e -w -z
nna       1453  1452  0 09:37 ?        00:00:01 /usr/local/bin/nfcapd -I 4 -l /usr/local/nagiosna/var/FPCSFibreRouter/flows -p 9912 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/FPCSFibreRouter/9912.pid -D -e -w -z
nna       1462     1  0 09:37 ?        00:00:03 /usr/local/bin/nfcapd -I 6 -l /usr/local/nagiosna/var/FPCSASA/flows -p 9914 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/FPCSASA/9914.pid -D -e -w -z
nna       1463  1462  0 09:37 ?        00:00:01 /usr/local/bin/nfcapd -I 6 -l /usr/local/nagiosna/var/FPCSASA/flows -p 9914 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/FPCSASA/9914.pid -D -e -w -z
nna       1471     1  0 09:37 ?        00:00:00 /usr/local/bin/nfcapd -I 7 -l /usr/local/nagiosna/var/FPCSADSLRouter/flows -p 9913 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/FPCSADSLRouter/9913.pid -D -e -w -z
nna       1472  1471  0 09:37 ?        00:00:01 /usr/local/bin/nfcapd -I 7 -l /usr/local/nagiosna/var/FPCSADSLRouter/flows -p 9913 -x /usr/local/nagiosna/bin/reap_files.py %d %f %i -P /usr/local/nagiosna/var/FPCSADSLRouter/9913.pid -D -e -w -z
root      6162  6060  0 15:14 pts/0    00:00:00 grep flow
djcomber
Post by djcomber »
looks like it was a login issue.. didn't catch it as I didn't realise the session was remember, odd that the browser kept me logged in and showed an empty page.
I had the web interface up when I upgraded.
Logged out and in again and all good.
Regards
David
bwallace
Post by bwallace »
Glad to hear you're back on track. This is odd behavior, I upgraded to the same version just a couple of days ago (same method to) and did not have any problems at all. I'll go ahead and lock this thread now, thanks.
