Cannot make SSL connection.
mdsupersonic
Post by mdsupersonic »
Hi Support team,
I'm trying to monitor an external website and in some points I'm receiving critical notification regarding ssl connection.
I want to check SLL certificate of that website and i'm getting 'CRITICAL - Cannot make SSL connection.'
Attached is the screenshot of the website.
Any help would be appreciated.
Regards
Re: Cannot make SSL connection.
Post by mcapra »
Can you show us the full check command being used for this service? Omitting the actual website if you have security considerations.
Is the check configured to use the proper port for the SSL connection?
mdsupersonic
-f ok -I 184.168.188.1 -u "/" -S -p 443
port should be 443
Post by mcapra »
Is the site front-facing? Can you run the site (assuming it is front-facing) through a service like SSLLabs and make sure everything checks out?
https://www.ssllabs.com/ssltest/
mdsupersonic
Assessment failed: No secure protocols supported
This website says this,but even with port 80 is not working.its something strange.
mdsupersonic
Please see the result in attach.
it seems it has TLS not SSL but nagios should monitor TLS too right?
Post by mcapra »
Do you know if the certificate was registered/configured to www.website.com or website.com? This could be where the conflict is occurring. Try removing the www from the host name.
From the command line, share the output of this:
/usr/local/nagios/libexec/check_http -H website.com --port=443 --ssl
mdsupersonic
Sorry there was some mistake in website URL I have fixed it everything working fine execept one service has Warning notification.
Post by mcapra »
Is the 404 response expected from this website? Do you get that response when you visit it in a web browser? You could try adding -e 404 to the arguments if a 404 response is expected.
mdsupersonic
No,I get the same error from the website.It means it is right notification.
Thank you for your help.
