i am trying to monitor VNC service via NSclient but getting error i have used this link for configuration,
http://www.kernelhardware.org/nagios-ns ... -services/
but i am getting error ..
[root@localhost ~]# service nagios restartRunning configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
[root@localhost ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.3.1
Last Modified: 07-25-2011
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows.cfg'...
Error: Could not find any hostgroup matching 'musewerx-72c7b0' (config file '/usr/local/nagios/etc/objects/windows.cfg', starting on line 156)
hopes for your suggestions ...
Thanks in Advance,
VNC Service Not Monitoring Via Nsclient??
Re: VNC Service Not Monitoring Via Nsclient??
The clue is here:- Error: Could not find any hostgroup matching 'musewerx-72c7b0' (config file '/usr/local/nagios/etc/objects/windows.cfg', starting on line 156)
Have you defined a hostgroup called musewerx-72c7b0? is there a typo?
mohsin2011
Thanks for your reply i have got the answer i was just getting error due to the wrong executable file i mentioned in the windows.cfg for monitoring service !
