SNMP log information writing to /var/log/messages in Nagios
raamardhani7
Post by raamardhani7 »
Hi Team,
SNMP log information is writing to /var/log/messages in Nagios XI server and it is filling the space on the server. could you please help me here. thanks.
Aug 23 09:20:27 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:27 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430400) 285 days, 0:05:04.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:20 DALCFCFW01 : %ASA-6-302013: Built inbound TCP connection 160295083 for outside:204.19.194.1/51374 (204.19.194.1/51374) to dmz244:172.30.244.206/20005 (172.30.244.206/20005)"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430400) 285 days, 0:05:04.00
Aug 23 09:20:27 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:27 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430400) 285 days, 0:05:04.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 5#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<164>Aug 23 2016 09:20:20 DALCFCFW01 : %ASA-4-106023: Deny udp src dmz244:DALCCFTPQ00/55500 dst outside:10.132.8.10/53 by access-group \"dmz244_access_in\" [0x0, 0x0]"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430400) 285 days, 0:05:04.00
Aug 23 09:20:27 lusrcdnagiosxi00 ndo2db: Error: mysql_query() failed for 'INSERT INTO nagios_logentries SET instance_id='1', logentry_time=FROM_UNIXTIME(1471948726), entry_time=FROM_UNIXTIME(1471948726), entry_time_usec='48376', logentry_type='2', logentry_data='Warning: Return code of 255 for check of service \'Server-Passive-Check\.Operational-Status\.Invalid-User-Count\' on host \'LUSSVPNAGIOSFUS01\.fossil\.com\' was out of bounds\.', realtime_data='1', inferred_data_extracted='1''
Aug 23 09:20:27 lusrcdnagiosxi00 ndo2db: mysql_error: 'Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed'
Aug 23 09:20:27 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:27 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430400) 285 days, 0:05:04.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:20 DALCFCFW01 : %ASA-6-302014: Teardown TCP connection 160295083 for outside:204.19.194.1/51374 to dmz244:172.30.244.206/20005 duration 0:00:00 bytes 13 TCP FINs"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430400) 285 days, 0:05:04.00
Aug 23 09:20:27 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:27 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302020: Built inbound ICMP connection for faddr 10.10.83.90/9294 gaddr 172.30.244.46/0 laddr 172.30.244.46/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:27 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:27 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302021: Teardown ICMP connection for faddr 10.10.83.90/9294 gaddr 172.30.244.46/0 laddr 172.30.244.46/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:28 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:28 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302020: Built inbound ICMP connection for faddr dalcpiq00/1 gaddr 172.28.101.1/0 laddr 172.28.101.1/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:28 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:28 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302021: Teardown ICMP connection for faddr dalcpiq00/1 gaddr 172.28.101.1/0 laddr 172.28.101.1/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:28 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:28 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302020: Built inbound ICMP connection for faddr 10.10.83.90/9294 gaddr 172.30.244.46/0 laddr 172.30.244.46/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:28 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:28 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302021: Teardown ICMP connection for faddr 10.10.83.90/9294 gaddr 172.30.244.46/0 laddr 172.30.244.46/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302021: Teardown ICMP connection for faddr 10.10.83.90/9294 gaddr 172.30.244.46/0 laddr 172.30.244.46/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302020: Built inbound ICMP connection for faddr 10.10.83.90/9294 gaddr 172.30.244.46/0 laddr 172.30.244.46/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302020: Built inbound ICMP connection for faddr 10.10.83.90/9395 gaddr 172.30.244.207/0 laddr 172.30.244.207/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302021: Teardown ICMP connection for faddr 10.10.83.90/9395 gaddr 172.30.244.207/0 laddr 172.30.244.207/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302013: Built inbound TCP connection 160295102 for outside:10.10.83.90/58118 (10.10.83.90/58118) to dmz244:172.30.244.207/12489 (172.30.244.207/12489)"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 5#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<164>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-4-106023: Deny udp src dmz244:DALCCTSD00/59450 dst outside:10.10.80.244/53 by access-group \"dmz244_access_in\" [0x0, 0x0]"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302014: Teardown TCP connection 160295101 for outside:10.10.83.90/58519 to dmz244:172.30.244.203/12489 duration 0:00:00 bytes 54 TCP FINs"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302020: Built inbound ICMP connection for faddr 172.30.246.35/0 gaddr 172.30.244.61/0 laddr 172.30.244.61/0"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:29 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:29 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 7#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<166>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-6-302014: Teardown TCP connection 160295103 for outside:10.10.83.90/58571 to dmz244:172.30.244.203/12489 duration 0:00:00 bytes 60 TCP FINs"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:30 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:30 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430500) 285 days, 0:05:05.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 5#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<164>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-4-106023: Deny udp src dmz244:172.30.244.203/54651 dst outside:10.146.8.10/53 by access-group \"dmz244_access_in\" [0x0, 0x0]"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430500) 285 days, 0:05:05.00
Aug 23 09:20:30 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:30 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430600) 285 days, 0:05:06.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 5#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<164>Aug 23 2016 09:20:21 DALCFCFW01 : %ASA-4-106023: Deny udp src dmz244:172.30.244.208/60062 dst outside:10.70.80.14/53 by access-group \"dmz244_access_in\" [0x0, 0x0]"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430600) 285 days, 0:05:06.00
Aug 23 09:20:30 lusrcdnagiosxi00 snmptrapd[6471]: 2016-08-23 09:20:30 <UNKNOWN> [UDP: [172.28.101.1]:162->[10.10.83.97]]:#012DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (2462430600) 285 days, 0:05:06.00#011SNMPv2-SMI::snmpModules.1.1.4.1.0 = OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.0 = STRING: "20"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.0 = INTEGER: 5#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.0 = STRING: "Syslog Trap"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.0 = STRING: "<164>Aug 23 2016 09:20:22 DALCFCFW01 : %ASA-4-106023: Deny udp src dmz244:172.30.244.209/58936 dst outside:10.142.8.10/53 by access-group \"dmz244_access_in\" [0x0, 0x0]"#011SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.0 = Timeticks: (2462430600) 285 days, 0:05:06.00
Re: SNMP log information writing to /var/log/messages in Nag
What OS are you running? This would require changing what logging you have SNMPD doing. This blog post explains what needs to be done for RHEL5, so probably a similar modification for RHEL6/7 -
https://raetsel.wordpress.com/2008/02/1 ... gmessages/
