baber
Posts: 308 Joined: Wed Oct 21, 2015 4:39 am
Post
by baber » Tue Aug 23, 2016 4:12 pm
dear all
hi
i am using check_disk.pl and my .cfg line this is
host_name npmbweb
service_description Disk Space
check_command check_nrpe!check_disk!' -w 20% -c 10% -W 20% -K 10% -e -A -i /mnt/cdrom'
and in nrpe.cfg this line add
command[check_disk]=/usr/local/nagios/libexec/check_disk.pl $ARG1$
now my problem is i don't want chk this path /media/cdrom or /media/* i change .cfg to this
host_name npmbweb
check_command check_nrpe!check_disk!' -w 20% -c 10% -W 20% -K 10% -e -A -i /media/cdrom'
this don't work and on my monitoring show /media/cdrom critical i don't want plugin chk this path /media/cdrom
how can sole that ?
BR
ssax
Dreams In Code
Posts: 7682 Joined: Wed Feb 11, 2015 12:54 pm
Post
by ssax » Tue Aug 23, 2016 4:47 pm
Please attach the check_disk.pl file that you are referring to so that we can review it (grab it from the remote host to make sure it's the exact one being run), the one that I found doesn't have the options that you're specifying.
Thank you
baber
Post
by baber » Tue Aug 23, 2016 11:22 pm
ssax wrote: Please attach the check_disk.pl file that you are referring to so that we can review it (grab it from the remote host to make sure it's the exact one being run), the one that I found doesn't have the options that you're specifying.
Thank you
the plugin has been attached
check_disk.pl
(13.09 KiB) Downloaded 616 times
ssax
Dreams In Code
Post
by ssax » Wed Aug 24, 2016 12:22 pm
Ok, yours doesn't have these options either:
-W 20% -K 10% -e -A .
Please change your service to:
host_name npmbweb
check_command check_nrpe!check_disk!' -w 20% -c 10% -i /mnt/cdrom'
Let us know if that works for you.
If it's still not working, please attach these files from the remote machine:
/usr/local/nagios/etc/nrpe/common.cfg
/usr/local/nagios/etc/nrpe.cfg
Thank you
baber
Post
by baber » Wed Aug 24, 2016 2:42 pm
ssax wrote: Ok, yours doesn't have these options either:
host_name npmbweb
Thank you
my problem not solved i have attached rpe.cfg from remote machine
nrpe.cfg
(8.86 KiB) Downloaded 537 times
ssax
Dreams In Code
Post
by ssax » Wed Aug 24, 2016 2:51 pm
You need to set
dont_blame_nrpe=1 in your nrpe.cfg because you're passing arguments.
Do you have this file?
baber
Post
by baber » Wed Aug 24, 2016 3:27 pm
ssax wrote: You need to set
no i don\t have common.cfg on my mahine
i use this
host_name npmbpndb
check_command check_nrpe!check_disk!' -w 20% -c 10% -i /media/cdrom'
and change dont_blame_nrpe=0
to
dont_blame_nrpe=1
but problem not work
what do i have to do ?
ssax
Dreams In Code
Post
by ssax » Wed Aug 24, 2016 3:46 pm
On the remote machine, please run these commands and send us the entire output:
su - nagios
/usr/local/nagios/libexec/check_disk.pl -w 20% -c 10% -i /mnt/cdrom
baber
Post
by baber » Wed Aug 24, 2016 10:15 pm
ssax wrote: On the remote machine, please run these commands and send us the entire output:
su - nagios
on remote machine when i installed nrpe agent created nagios user with nologin permission
nagios
503:504::/home/nagios:/sbin/nologin
[root@baber ~]# su - nagios
This account is currently not available.
on all of my machine is on this mode and is ok
i run this command with root user
[root@baber ~]# /usr/local/nagios/libexec/check_disk.pl -w 20% -c 10% -i /media/cdrom
Erreur : unite inconnue (%)
DISK OK
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Thu Aug 25, 2016 11:52 am
Try running the following command instead:
/usr/local/nagios/libexec/check_disk.pl -w 20 -c 10 -i /media/cdrom
Are the errors gone?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
