I am facing a issue whose details are as below :-
Nagios Core 4.2.0
Last Modified: 08-01-2016
License: GPL
Reading configuration data...
Read main config file okay...
Error: Could not find a service matching host name 'nodejs01.example.in' and description 'check_rabbitmq_example_smsqueue' (config file '/usr/local/nagios/etc/objects/servicegroups.cfg', starting on line 1)
Error: Could not expand members specified in servicegroup 'rabbitmqqueues' (config file '/usr/local/nagios/etc/objects/servicegroups.cfg', starting at line 1)
cat nodejs01.example.in.cfg
host_name nodejs01.example.in
service_description Check Rabbit MQ SMS Queue
check_command check_nrpe!check_rabbitmq_example_smsqueue
servicegroups rabbitmqqueues
service_description Check Rabbit MQ Email Queue
check_command check_nrpe!check_rabbitmq_example_emailqueue
define servicegroup{
servicegroup_name rabbitmqqueues
alias RabbitMQ Helpcchat queues
members nodejs01.example.in,check_rabbitmq_example_smsqueue,nodejs01.example.in,check_rabbitmq_example_emailqueue
hostname :- nodejs01.example.in
service :- check_rabbitmq_example_smsqueue
service :- check_rabbitmq_example_emailqueue
Any help will be highly appreciable.
Thanks and Regards,
Kaushal
kaushalshriyan
Re: Error: Could not find a service matching host name
Can you show us your host definition for nodejs01.example.in as well?
kaushalshriyan
Hi Robert,
Please find the below details :-
host definition :- http://sprunge.us/hGSg located inside /usr/local/nagios/etc/servers
cat nagios.cfg -> http://sprunge.us/KYEY in /usr/local/nagios/etc
Regards,
Kaushal
Regards,
Kaushal
kaushalshriyan
Hi Robert,
cfg_dir=/usr/local/nagios/etc/servers as mentioned in nagios.cfg file located inside /usr/local/nagios/etc directory
Regards,
Kaushal
Regards,
Kaushal
- Box293
- Too Basu
You do not have a service called check_rabbitmq_example_smsqueue, your service is called Check Rabbit MQ SMS Queue.kaushalshriyan wrote:Error: Could not find a service matching host name 'nodejs01.example.in' and description 'check_rabbitmq_example_smsqueue' (config file '/usr/local/nagios/etc/objects/servicegroups.cfg', starting on line 1)
Your servicegroup definition should be:
members nodejs01.example.in,Check Rabbit MQ SMS Queue,nodejs01.example.in,Check Rabbit MQ Email Queue
}As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
