We have had Nagios core up and running for over a year now without issue until recently. One of the check_http checks starting throwing an odd message that I cannot find much help with.
The error message cites "CRITICAL - Cannot create SSL context". I am using the command: check_http -H IP.ADDRESS.OF.MACHINE --ssl=3 -p 443 but cannot figure out why it suddenly started throwing the error.
I tried the same test on a different webserver and replicated the same error message, so I am thinking I may need to upgrade the SSL lib, I am not exactly sure if I need to do this or even exactly HOW to do this.
If I swap the command for check_http -S -H IP.ADDRESS.OF.MACHINE -p 443 it returns CANNOT MAKE SSL CONNECTION.
Any ideas?
Re: Cannot create SSL context
Can you add the -v option to your command to get a verbose output and post it here so we can view the error?
I talked with our C dev and he said that either the SSL libraries went missing or new SSL libraries were added and you need to recompile your nagios plugins.
What Linux distro/version are you running Core on?
