my script not work correctly but directly work on server
baber
Post by baber »
Dear all
Hi
i have downloaded attach plugin when i use this plugin on my linux server this output appear
[root@npmbsrv libexec]# ./check_cciss-1.12 -v
RAID OK:  Smart Array P420i in Slot 0 (Embedded) array A logicaldrive 1 (279.4 GB, RAID 1, OK) array B logicaldrive 2 (279.4 GB, RAID 1, OK) array C logicaldrive 3 (279.4 GB, RAID 1, OK) [Controller Status: OK Cache Status: OK Battery/Capacitor Status: OK]
and
[root@npmbsrv libexec]# ./check_cciss-1.12 -p
RAID OK
and add this in my cfg machine
        use                            generic-service
        host_name                      npmbsrv
        service_description            Disk Raid
        check_command                  check_nrpe!check_cciss-1.12
then add this line in nrpe.cfg file
command[check_cciss-1.12]=/usr/local/nagios/libexec/check_cciss-1.12 -v -p
but output on nagios monitoring show this
RAID UNKNOWN - /usr/sbin/hpacucli did not execute properly : sudo: sorry, you must have a tty to run sudo
even i used this
command[check_cciss-1.12]=sudo /usr/local/nagios/libexec/check_cciss-1.12 -v -p
and this error appear on monitoring
NRPE: Unable to read output
now what is my problem ? i am realy confused when i run directly on physical server get output but when want run from nagios not work
Best regards
check_cciss-1.zip
(3.29 KiB) Downloaded 256 times
eloyd
Cool Title Here
Re: my script not work correctly but directly work on server
Post by eloyd »
This is your problem:
There are lots of threads on this, but I'll save you the problem and give you the answer. You need to add this to your sudoers file through the "visudo" command on the remote host that you're trying to execute the code on (via NRPE):
# NEEDED TO ALLOW NAGIOS TO CHECK SERVICE STATUS
Defaults:nagios !requiretty
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_service
baber
Post by baber »
eloyd wrote:This is your problem:
thanks
but my problem not solved
i have add these line at the end of sudoers file on my remote physical server
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_cciss-1.12
and in nrpe.cfg this line
now in monitoring this error appear
RAID UNKNOWN - /usr/sbin/hpacucli did not execute properly : sudo: no tty present and no askpass program specified
what do i have to do ?
eloyd
Cool Title Here
Post by eloyd »
Make sure the lines you added are at the end of the sudoers file, not the beginning.
baber
Post by baber »
eloyd wrote:Make sure the lines you added are at the end of the sudoers file, not the beginning.
exactly in end of file
"/etc/sudoers" [readonly] 119L, 3940C        119,1         Bot
eloyd
Cool Title Here
Post by eloyd »
Change
to
baber
Post by baber »
eloyd wrote:Change
to
i have changed but another this error appear
eloyd
Cool Title Here
Post by eloyd »
Is your remote code running as the nagios user or something else? If it's something else, you need to update the sudoers file with the appropriate username.
baber
Post by baber »
eloyd wrote:Is your remote code running as the nagios user or something else? If it's something else, you need to update the sudoers file with the appropriate username.
i run script with root user
RAID OK
[root@npmbsrv libexec]# ll check_cciss-1.12
-rwxr-xr-x 1 nagios nagios 14514 Aug 25 16:39 check_cciss-1.12
[root@npmbsrv libexec]# su - nagios
This account is currently not available.
[root@npmbsrv libexec]# cat /etc/passwd
nagios:x:503:504::/home/nagios:/sbin/nologin
eloyd
Cool Title Here
Post by eloyd »
I mean, on the remote server, is your NRPE running as the nagios user or some other user? Can you look at the end of /var/log/secure and post the last 50 lines or so?
