I am trying to install NNA and I am running into issues while installing it. Need your help in sorting this for me.
[root@lussvpnna00 nagiosna]# ll
total 2112
drwxr-xr-x. 7 root root 4096 Aug 12 14:30 backend
-rw-r--r--. 1 root root 410 Aug 12 14:30 build_dev_tarball.py
-rw-r--r--. 1 root root 9813 Aug 12 14:30 CHANGELOG.txt
-rw-r--r--. 1 root root 812 Aug 12 14:30 config.local.php
drwxr-xr-x. 2 root root 4096 Aug 12 14:30 doc
-rwxr-xr-x. 1 root root 6686 Aug 12 14:30 fullinstall
-rw-r--r--. 1 root root 196 Aug 12 14:30 httpd.nagiosna.conf
-rw-------. 1 root root 4776 Aug 25 03:06 install.log
-rwxr-xr-x. 1 root root 13694 Aug 12 14:30 libinstall.sh
drwxr-xr-x. 2 root root 4096 Aug 12 14:30 mibs
drwxr-xr-x. 6 root root 4096 Aug 12 14:30 nagiosna
-rw-r--r--. 1 root root 290 Aug 12 14:30 nagiosna.cron
-rw-r--r--. 1 root root 237 Aug 12 14:30 nagiosna.service
-rw-r--r--. 1 root root 11356 Aug 12 14:30 nagiosna.sql
-rw-r--r--. 1 root root 575 Aug 12 14:30 nagiosna.sudoers
-rw-r--r--. 1 root root 662006 Aug 12 14:30 nfdump-1.6.13.tar.gz
-rw-r--r--. 1 root root 1385640 Aug 12 14:30 rrdtool-1.4.9.tar.gz
drwxr-xr-x. 2 root root 4096 Aug 12 14:30 sourceguardian
-rwxr-xr-x. 1 root root 5055 Aug 12 14:30 upgrade
[root@lussvpnna00 nagiosna]# ls
backend config.local.php httpd.nagiosna.conf mibs nagiosna.service nfdump-1.6.13.tar.gz upgrade
build_dev_tarball.py doc install.log nagiosna nagiosna.sql rrdtool-1.4.9.tar.gz
CHANGELOG.txt fullinstall libinstall.sh nagiosna.cron nagiosna.sudoers sourceguardian
[root@lussvpnna00 nagiosna]# yum repolist all
Loaded plugins: changelog, product-id, rhnplugin, security, subscription-manager
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
This system is not registered with RHN Classic or RHN Satellite.
You can use rhn_register to register.
RHN Satellite or RHN Classic support will be disabled.
repo id repo name status
epel Extra Packages for Enterprise Linux 6 - x86_64 enabled: 12,192
epel-debuginfo Extra Packages for Enterprise Linux 6 - x86_64 - Debug disabled
epel-source Extra Packages for Enterprise Linux 6 - x86_64 - Source disabled
epel-testing Extra Packages for Enterprise Linux 6 - Testing - x86_64 disabled
epel-testing-debuginfo Extra Packages for Enterprise Linux 6 - Testing - x86_64 - Debug disabled
epel-testing-source Extra Packages for Enterprise Linux 6 - Testing - x86_64 - Source disabled
rhel-source Red Hat Enterprise Linux 6Server - x86_64 - Source disabled
rhel-source-beta Red Hat Enterprise Linux 6Server Beta - x86_64 - Source disabled
repolist: 12,192
epel Extra Packages for Enterprise Linux 6 - x86_64 12,192
repolist: 12,192
[root@lussvpnna00 nagiosna]# yum-config-manager --enable rhel-6-server-optional-rpms
Loaded plugins: product-id, rhnplugin
[root@lussvpnna00 nagiosna]# cat /etc/*release
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Red Hat Enterprise Linux Server release 6.6 (Santiago)
[root@lussvpnna00 nagiosna]# yum update
Setting up Update Process
No Packages marked for Update
more install.log
Nagios Network Analyzer Installation
DATE: Thu Aug 25 03:05:37 CDT 2016
DISTRO INFO:
RedHatEnterpriseServer
6.6
x86_64
Running 'prereqs'...
Enabling epel repo...
6
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 14540 100 14540 0 0 59200 0 --:--:-- --:--:-- --:--:-- 2366k
warning: epel-release-latest-6.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID 0608b895: NOKEY
Preparing... ##################################################
epel-release ##################################################
epel-release RPM installed OK
Setting up Install Process
No package mysql-server available.
No package php-mysql available.
No package php-ldap available.
No package sendmail available.
No package gcc available.
No package flex available.
No package byacc available.
No package libxml2-devel available.
No package pango-devel available.
No package cairo-devel available.
No package glib2-devel available.
No package python-devel available.
No package net-snmp available.
No package net-snmp-utils available.
No package xorg-x11-fonts-75dpi available.
No package dejavu-serif-fonts available.
Warning: Group chinese-support does not have any packages.
Warning: Group japanese-support does not have any packages.
Warning: Group russian-support does not have any packages.
Resolving Dependencies
--> Running transaction check
---> Package php-mcrypt.x86_64 0:5.3.3-4.el6 will be installed
--> Processing Dependency: libmcrypt.so.4()(64bit) for package: php-mcrypt-5.3.3-4.el6.x86_64
---> Package libmcrypt.x86_64 0:2.5.8-9.el6 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
php-mcrypt x86_64 5.3.3-4.el6 epel 19 k
Installing for dependencies:
libmcrypt x86_64 2.5.8-9.el6 epel 96 k
Transaction Summary
Install 2 Package(s)
Total download size: 114 k
Installed size: 326 k
Downloading Packages:
Total 244 kB/s | 114 kB 00:00
warning: rpmts_HdrFromFdno: Header V3 RSA/SHA256 Signature, key ID 0608b895: NOKEY
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
Importing GPG key 0x0608B895:
Userid : EPEL (6) <[email protected]>
Package: epel-release-6-8.noarch (installed)
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Warning: RPMDB altered outside of yum.
Installing : libmcrypt-2.5.8-9.el6.x86_64 1/2
Installing : php-mcrypt-5.3.3-4.el6.x86_64 2/2
Verifying : php-mcrypt-5.3.3-4.el6.x86_64 1/2
Verifying : libmcrypt-2.5.8-9.el6.x86_64 2/2
Installed:
Dependency Installed:
Complete!
ERROR: Prerequisites failed to install.
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
