I am a new user on Nagios core and it was working good till last week but now when i am trying to access the web interface of it the connection is failing and the browser says "The system returned: (113) No route to host
The remote host or network may be down. Please try the request again". Nagios core is installed on Centos.
Thank you
Unable to access Web interface for Nagios Core
Re: Unable to access Web interface for Nagios Core
Can you SSH into the server?
Try running this command:
Are you accessing via IP or DNS name?
What is the output of this command:
Thank you
curl localhostWhat is the output of this command:
netstat -rnThank you
Also, run this command:
And let it run and then try to connect to the web interface and attach the output so that we can review it.
Thank you
tail -f /var/log/httpd/*error_log /var/log/httpd/*access_logThank you
