Notification just one host
casilva
Post by casilva »
Sorry, I don' t speak english, but a will try write my doubt.
I have 2 hosts and they are the same configuration, service definition and host definition.
Both hosts are down, but when I start nagios I received notification only to 1 host.
I configured my contact for send telegram.
I would like to know, why I am receiving just one message if the 2 hosts are down.
Follow the files that I used for my configuration:
Configuration of hosts1
        use                     linux-server            ; Name of host template to use
                                                        ; This host definition will inherit all variables that are defined
                                                        ; in (or inherited by) the linux-server host template definition.
        host_name               kibana
        alias                   Kibana
        address                 host-kibana
        use                             local-service,graphed-service         ; Name of service template to use
        host_name                       kibana
        service_description             Check - Ping host
        check_command                   check_ping!100.0,20%!500.0,60%
        contacts                Telegram Group Chat
host 2
        host_name               elasticsearch
        alias                   Elasticsearch
        address                 host-elasticsearch
contacts
define contact {
        contact_name                    Telegram Group Chat
        pager                           xxxx
        service_notification_commands   notify-service-by-telegram
        host_notification_commands      notify-host-by-telegram
        service_notification_period     24x7                    ; service notifications can be sent anytime
        host_notification_period        24x7                    ; host notifications can be sent anytime
        service_notification_options    w,u,c,r,f,s             ; send notifications for all service states, flapping events, and scheduled downtime events
        host_notification_options       d,u,r,f,s               ; send notifications for all host states, flapping events, and scheduled downtime events
        host_notifications_enabled              1
        service_notifications_enabled   1
templates
define contact{
        name                            generic-contact    	; The name of this contact template
        service_notification_commands   notify-service-by-email	; send service notifications via email
        host_notification_commands      notify-host-by-email	; send host notifications via email
        register                        0       		; DONT REGISTER THIS DEFINITION - ITS NOT A REAL CONTACT, JUST A TEMPLATE!
        name                            generic-host    ; The name of this host template
        notifications_enabled           1       	; Host notifications are enabled
        event_handler_enabled           1       	; Host event handler is enabled
        flap_detection_enabled          1       	; Flap detection is enabled
        process_perf_data               1       	; Process performance data
        retain_status_information       1       	; Retain status information across program restarts
        retain_nonstatus_information    1       	; Retain non-status information across program restarts
	notification_period		24x7		; Send host notifications at any time
        register                        0       	; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
# Linux host definition template - This is NOT a real host, just a template!
	name				linux-server	; The name of this host template
	use				generic-host	; This template inherits other values from the generic-host template
	check_period			24x7		; By default, Linux hosts are checked round the clock
	check_interval			1		; Actively check the host every 5 minutes
	retry_interval			1		; Schedule host check retries at 1 minute intervals
	max_check_attempts		1		; Check each Linux host 10 times (max)
        check_command           	check-host-alive ; Default command to check Linux hosts
	notification_period		workhours	; Linux admins hate to be woken up, so we only notify during the day
							; Note that the notification_period variable is being overridden from
							; the value that is inherited from the generic-host template!
	notification_interval		0		; Resend notifications every 2 hours
	notification_options		d,u,r		; Only send notifications for specific host states
	contact_groups			admins		; Notifications get sent to the admins by default
        name                            generic-service 	; The 'name' of this service template
        active_checks_enabled           1       		; Active service checks are enabled
        passive_checks_enabled          1    		   	; Passive service checks are enabled/accepted
        parallelize_check               1       		; Active service checks should be parallelized (disabling this can lead to major performance problems)
        obsess_over_service             1       		; We should obsess over this service (if necessary)
        check_freshness                 0       		; Default is to NOT check service 'freshness'
        notifications_enabled           1       		; Service notifications are enabled
        event_handler_enabled           1       		; Service event handler is enabled
        is_volatile                     0       		; The service is not volatile
        check_period                    24x7			; The service can be checked at any time of the day
        max_check_attempts              1			; Re-check the service up to 3 times in order to determine its final (hard) state
        normal_check_interval           1			; Check the service every 10 minutes under normal conditions
        retry_check_interval            1			; Re-check the service every two minutes until a hard state can be determined
        contact_groups                  admins			; Notifications get sent out to everyone in the 'admins' group
	notification_options		w,u,c,r			; Send notifications about warning, unknown, critical, and recovery events
        notification_interval           0			; Re-notify about service problems every hour
        notification_period             24x7			; Notifications can be sent out at any time
         register                        0       		; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
	name				local-service 		; The name of this service template
	use				generic-service		; Inherit default values from the generic-service definition
        max_check_attempts              1			; Re-check the service up to 4 times in order to determine its final (hard) state
        normal_check_interval           1			; Check the service every 5 minutes under normal conditions
        retry_check_interval            1			; Re-check the service every minute until a hard state can be determined
        name                            graphed-service
        action_url                      /cgi-bin/show.cgi?host=$HOSTNAME$&service=$SERVICEDESC$' onMouseOver='showGraphPopup(this)' onMouseOut='hideGraphPopup()' rel='/cgi-bin/showgraph.cgi?host=$HOSTNAME$&service=$SERVICEDESC$&period=day&rrdopts=-w+450+-j
        register                        0
Re: Notification just one host
Is the host that you didn't receive the notification setup for Downtime or that it is acknowledged that is is down?
That would stop the Notifications for that one host from being sent.
casilva
Post by casilva »
I solved my problem, I don't know why just one host was receiving notification, but my problem it was the period of notification.
Sometimes I was testing in a valid period, sometimes in a invalid period, after this problem I discovered it.
Before the host define in templates it was:
Now is:
Thanks!!!!
Thanks for reporting your findings, shall I mark this post as solved and lock it up?
