Install nrpe on Ubuntu
Naveed
Post by Naveed »
I want to monitor my ubuntu servers with nagios xi.
I have successfully installed nrpe on ubuntu which is listening on port 5666 with localhost by following below How to
http://tecadmin.net/install-nrpe-on-ubuntu/#
I have added nagios IP address in /etc/nagios/nrpe.cfg and restart the service...
Firewall service is also disabled.
But I am unable to ping it from nagios and as I test it from nagios server by following command...
its just timeout after 10 seconds...
Nagios XI
/usr/local/nagios/libexec/check_nrpe -H client ip -p 5666
check nrpe service check timeout out after 10 seconds
Kindly assist..
Thank you!
Re: Install nrpe on Ubuntu
Post by mcapra »
That website appears to be offline, so pointing out potentially wrong steps is going to be difficult.
Are you able to run through our official documentation and describe problematic steps?
https://assets.nagios.com/downloads/nag ... _Agent.pdf
bwallace
Post by bwallace »
Socket timeout errors can be caused by the remote system not responding to the check. Either the command is formatted incorrectly, the server is not responding, or the target ip is wrong. It can also be caused by firewall issues, or route issues. It is a catchall error for when the checked system does not respond.
Checking nagios.log and running the most basic form of the check from the cli can shed some light on the problems. Port mapping the checked port from the nagios server can help as well. Otherwise you will need to check the remote system's associated logs for the checked service for any clues.
1) From Nagios's perspective, is port 5666 open? Run the following commands from the CLI on the nagios server and show us the output:
nmap <client ip> -p 5666
2) /usr/local/nagios/libexec/check_nrpe -H <client ip> (run this one few times then immediately run the cmd below)
tail -50 /var/log/messages
Naveed
Post by Naveed »
[root@AXmonitor libexec]# nmap 13.88.19.123 -p 5666
Starting Nmap 6.47 ( http://nmap.org ) at 2016-08-29 06:58 PDT
Note: Host seems down. If it is really up, but blocking our ping probes, try -Pn
Nmap done: 1 IP address (0 hosts up) scanned in 3.15 seconds
I have reinstalled the nrpe agent by following nagios xi documentation
root@HADB02:/usr/lib/nagios/plugins# ./check_nrpe -H 13.88.19.123
CHECK_NRPE: Error - Could not complete SSL handshake.
root@HADB02:/usr/lib/nagios/plugins# ./check_nrpe -H 127.0.0.1
CHECK_NRPE: Socket timeout after 10 seconds.
Kindly see the guide further.
Thank you!
bwallace
Post by bwallace »
That's nmap's way of saying the results are inconclusive. Nmap scans in stages and it uses ping for stage 1. Some FW / hosts don't respond to ping, hence the message "Host seems down. If it is really up, but blocking our ping probes, try -Pn"
Try using -Pn as it suggests, this will cause nmap to not use ping and we should get more accurate results.
From your Nagios XI server execute this command and provide the output (Where xxx is the IP address of the remote server):
nmap -Pn -p T:5666 xxx
Naveed
Post by Naveed »
Thank you!
[root@AXmonitor vmn]# nmap -Pn -p T:5666 1.2.3.4
Starting Nmap 6.47 ( http://nmap.org ) at 2016-08-29 08:09 PDT
Nmap scan report for 1.2.3.4
Host is up (0.060s latency).
PORT STATE SERVICE
5666/tcp open nrpe
Nmap done: 1 IP address (1 host up) scanned in 0.21 seconds
Moreover I am testing it from client side as well.
On client side
root@HADB02:/usr/lib/nagios/plugins# ./check_nrpe -H 1.2.3.4
Kindly guide this about it as well.
Thank you!
bwallace
Post by bwallace »
Allright, now we know the target machine is indeed reachable from the Nagios box - thanks.
Since you're getting ""Could not complete SSL handshake" when run on the client, I'm betting that NRPE was not compiled with ssl enabled. Please run the following command from the Nagios server. If it works, then NRPE on the client was compiled without ssl support (the -n switch disables the use of SSL).
/usr/local/nagios/libexec/check_nrpe -H <remote host ip> -n
Also, if the problem persists, refer to section III of this doc and let us know what additional steps you took.
https://assets.nagios.com/downloads/nag ... utions.pdf
Naveed
Post by Naveed »
Now I can ping my host and server together after allowing from azure end points configurations and inbound/outbound rules.
command[check_users]=/usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_cpu]=/usr/lib/nagios/plugins/check_cpu -c 05 -w 10
command[check_load]=/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
command[check_hda1]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/hda1
command[check_zombie_procs]=/usr/lib/nagios/plugins/check_procs -w 5 -c 10 -s Z
command[check_procs]=/usr/lib/nagios/plugins/check_procs -w 400 -c 500
command[check_ssh]=/usr/lib/nagios/plugins/check_ssh -H 127.0.0.1 -p22
command[check_swap]=/usr/lib/nagios/plugins/check_swap -w 30 -c 20
command[check_memory]=/usr/lib/nagios/plugins/check_memory -f -w 8 -c 5
command[check_disk]=/usr/lib/nagios/plugins/check_disk -w 08% -c 05% -p /
command[check_ntp]=/usr/lib/nagios/plugins/check_ntp -H 127.0.0.1 -w 10 -c 20
command[check_uptime]=/usr/lib/nagios/plugins/check_uptime
command[check_tcp22]=/usr/lib/nagios/plugins/check_tcp -H 127.0.0.1 -p 22 -w 30 -c 20
command[check_tcp5666]=/usr/lib/nagios/plugins/check_tcp -H 127.0.0.1 -p 5666 -w 30 -c 20
command[check_open_files]=/usr/lib/nagios/plugins/check_open_files -c 30 -w 50
my /etc/nagios/nrpe.cfg file
Please recommend what log messages we need to see for alerts.
I have already checked,
/var/log/syslog
/var/log/auth.log
You should be able to find some clues in the "/var/log/syslog".
Can you run the following commands and show the output?
on the client:
on the Nagios XI server:
/usr/local/nagios/libexec/check_nrpe -H <client ip> -n
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_users
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_cpu
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_load
Naveed
Post by Naveed »
root@HAWEB02:/home/GIRU# /usr/lib/nagios/plugins/check_users -w 5 -c 10
USERS OK - 1 users currently logged in |users=1;5;10;0
root@HAWEB02:/home/GIRU# /usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
OK - load average: 0.00, 0.06, 0.11|load1=0.000;15.000;30.000;0; load5=0.060;10.000;25.000;0; load15=0.110;5.000;20.000;0;
[root@AXmonitor vmn]# nmap 1.2.3.4 -p 5666
Starting Nmap 6.47 ( http://nmap.org ) at 2016-08-29 12:53 PDT
PORT STATE SERVICE
5666/tcp open nrpe
Nmap done: 1 IP address (1 host up) scanned in 0.25 seconds
[root@AXmonitor vmn]# /usr/local/nagios/libexec/check_nrpe -H 1.2.3.4
NRPE v2.15
[root@AXmonitor vmn]# /usr/local/nagios/libexec/check_nrpe -H 1.2.3.4 -n
CHECK_NRPE: Error receiving data from daemon.
[root@AXmonitor vmn]# /usr/local/nagios/libexec/check_nrpe -H 1.2.3.4 -c check_users
NRPE: Unable to read output
[root@AXmonitor vmn]# /usr/local/nagios/libexec/check_nrpe -H 1.2.3.4 -c check_load
