Nagiosgraph 1.52 and Nagios 4.2.0
emi65
Post by emi65 »
nagiosgraph.conf
/etc/httpd/conf.d/
(570 Bytes) Downloaded 360 times
Hi expert
I installed the nagios version 4.2.0 and and after this installation Nagiosgraph problem is appear .
I using Nagiograph 1.52
Now when I attempt to get nagiosgraph page I got this error
JavaScript is disabled.
nagiosgraph.js is not installed or wrong version
I attach my httpd.con , nagios.conf and my nagiosgraph.conf files
Please some one could help me
Regards
Emilio
nagios.conf
/etc/httpd/conf.d/
(2.19 KiB) Downloaded 368 times
httpd.conf
/etc/httpd/conf
(33.61 KiB) Downloaded 362 times
emi65
Re: Nagiosgraph 1.52 JavaScript is disabled [SOLVED]
Post by emi65 »
I solved the problem !!!
A wrong check , put "bad" character in the nagios performance field
Nagiograph was created a file like this
UX_Check_JBO_HCMP0_BOP_A_web___exception%20occurred%3A%20javax.management.AttributeNotFoundException%3A%20JBAS014749%3A%20Operation%20handler%20failed%3A%20null.%20See%20the%20log%20file%20for%20error%20details.%3B45%3B50%20JBO002_HCMP0_A.rrd
When show.cgi attempt to read this file ... "became crazy" and give the error
I disabled the check and I removed the file and now ALL WORK FINE !!!
bye
Emilio
Re: Nagiosgraph 1.52 and Nagios 4.2.0
Post by mcapra »
Thanks for sharing your solution! Is it alright if we lock this thread and mark the issue as resolved?
emi65
Post by emi65 »
Yes , you can do it
