NRPE: Unable to read output
sachinmw
Post by sachinmw »
output from local host
/usr/local/nagios/libexec/check_nrpe -H localhost
NRPE v2.15
 /usr/local/nagios/libexec/check_init_service sshd  openssh-daemon (pid  5643) is running...
output from nagios server
/usr/local/nagios/libexec/check_nrpe -H 172.166.255.30
NRPE v2.15
/usr/local/nagios/libexec/check_nrpe -H 172.166.255.30 -c check_init_service -a sshd
contents of /etc/xinted.d/nrpe
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
        flags           = REUSE
        socket_type     = stream
        port            = 5666
        wait            = no
        user            = nagios
        group           = nagios
        server          = /usr/local/nagios/bin/nrpe
        server_args     = -c /usr/local/nagios/etc/nrpe.cfg --inetd
        log_on_failure  += USERID
        disable         = no
        only_from       = Server.IP 127.0.0.1
I have tried all solutions I could find about this issue
any ideas what I am missing?
Re: NRPE: Unable to read output
The error you are receiving usually comes from either the plugin is not installed on the remote system or that the command settings in the nrpe.cfg is not setup correctly.
Make sure that the plugin is installed on the remote system and that the path for the command is defined correctly.
Also, that plugin's owner and group is the nagios user and that the nagios user can run it.
You also need to add the following in the /etc/sudoers file.
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_service
Try that and let us know if this fixes the issue.
sachinmw
Post by sachinmw »
nagios is installed
#find / -name nrpe
/etc/xinetd.d/nrpe
netstat
#netstat -at | grep nrpe
tcp        0      0 *:nrpe                      *:*                         LISTEN
since nrpe is running via xinetd
/usr/local/nagios/etc/nrpe/common.cfg file
common.cfg.txt
(1.49 KiB) Downloaded 370 times
/usr/local/nagios/etc/nrpe.cfg file
nrpe.cfg.txt
(7.24 KiB) Downloaded 404 times
permissions and ownership
ls -l /usr/local/nagios/libexec/check_init_service
-rwxr-xr-x 1 nagios nagios 748 Feb  9  2016 /usr/local/nagios/libexec/check_init_service
sudoers file
# grep nagios /etc/sudoers
User_Alias NAGIOS_USERS = %nagios
User_Alias NAGIOSXI_USERS=nagios
Cmnd_Alias NAGIOS_CMDS = /usr/local/nagios/libexec/check_init_service, /usr/local/nagios/libexec/check_mountpoints.sh
Cmnd_Alias NAGIOSXI_CMDS  = /etc/init.d/nagios *, /etc/init.d/ndo2db *, /etc/init.d/npcd *, /usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *, /usr/local/nagiosxi/html/includes/components/profile/getprofile.sh, /usr/local/nagiosxi/scripts/upgrade_to_latest.sh, /usr/local/nagiosxi/scripts/change_timezone.sh, /usr/local/nagiosxi/scripts/manage_services.sh *, /usr/local/nagiosxi/scripts/reset_config_perms.sh
Cmnd_Alias NAGIOSXIWEB_CMDS = /usr/bin/tail -100 /var/log/messages, /usr/bin/tail -100 /var/log/httpd/error_log, /usr/bin/tail -100 /var/log/mysqld.log, /usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *, /usr/local/nagiosxi/html/includes/components/profile/getprofile.sh, /etc/init.d/snmptt restart, /usr/local/nagiosxi/scripts/repair_databases.sh, /usr/local/nagiosxi/scripts/manage_services.sh *
Defaults:nagios !requiretty
# grep NAGIOS_CMDS /etc/sudoers
NAGIOS_USERS ALL=NOPASSWD: NAGIOS_CMDS
Can you login to the remote server as the nagios user and run the command?
Run the following and post the output.
chage -l nagios
su nagios
sudo /usr/local/nagios/libexec/check_init_service sshd
sachinmw
Post by sachinmw »
[[email protected] ~]# chage -l nagios
Last password change                                    : Feb 02, 2016
Password expires                                        : May 02, 2016
Password inactive                                       : never
Account expires                                         : never
Minimum number of days between password change          : 0
Maximum number of days between password change          : 90
Number of days of warning before password expires       : 5
[[email protected] ~]# su nagios
[[email protected] root]$ /usr/local/nagios/libexec/check_init_service sshd
[[email protected] root]$ sudo /usr/local/nagios/libexec/check_init_service sshd
Edit the common.cfg file and change this line from
command[check_init_service]=sudo /usr/local/nagios/libexec/check_init_service $ARG1$
to
command[check_init_service]=/usr/local/nagios/libexec/check_init_service $ARG1$
Let us know if this works for you.
