How to monitor Mountpoint In Aix Servers
gselvakumar
Post by gselvakumar »
Hi Team,
Is there any plugin that can check mount points in AIX servers. It should compare the current file system mounted with the /etc/filesystem file and returns CRITICAL if some file system is not mounted.I had found one in nagios exchange but that is German language which is not helping me.Is there any thing other plugin apart from the one mentioned below.
https://exchange.nagios.org/directory/P ... sh/details
Gomathyshankar Selvakumar
Thanks & Regards,
Re: How to monitor Mountpoint In Aix Servers
The plugin should still work, regardless of language, but you'll need to translate it. It's actually Spanish, not German.
I believe the lines below are the only ones that need to be changed.
		echo " falsa alarma no tiene q estar montado"  > /dev/null
	else
		echo "$fs NO esta montado " >> ${WORK_DIR}/fs.txt.not.mounted
becomes -
		echo " false alarm does not have to be mounted."  > /dev/null
	else
		echo "$fs is not mounted. " >> ${WORK_DIR}/fs.txt.not.mounted
gselvakumar
Thanks & Regards,
What issues did you run into with the initial plugin you posted? I showed you what needed to be changed so that it would output in english.
