Suppress Notification of UP after UNREACHABLE (FIXED!)
SRSchnell
Post by SRSchnell »
Good day,
I'm trying to find out if anyone has come up with a way to suppress UP notification for a HOST after it has been in an UNREACHABLE state.
Now that I think about it, it would also be nice to get the DOWN notifications after UNREACHABLE. Thus limiting the number of notifications after and outage/recovery scenario and possibly getting quicker problem notifications for children further down the tree.
R
ssax
Dreams In Code
Re: Suppress Notification of UP after UNREACHABLE
Post by ssax »
You would need to write a notification handler script and pass in the $LASTHOSTSTATE$ macro, then if current state $HOSTSTATE$ = 'UP', exit.
       command_name                  		notify-host-by-email
       command_line                  		        /usr/local/nagios/libexec/host_notification_handler.sh $NOTIFICATIONTYPE$ $HOSTNAME$ $HOSTSTATE$ $LASTHOSTSTATE$ $HOSTADDRESS$ $HOSTOUTPUT$ $LONGDATETIME$ $CONTACTEMAIL$
#!/bin/bash
# /usr/local/nagios/libexec/host_notification_handler.sh
NOTIFICATIONTYPE="$1"
HOSTNAME="$2"
HOSTSTATE="$3"
LASTHOSTSTATE="$4"
HOSTADDRESS="$5"
HOSTOUTPUT="$6"
LONGDATETIME="$7"
CONTACTEMAIL="$8"
if [ "$LASTHOSTSTATE" = "UNREACHABLE" ] && [ "$HOSTSTATE" = "UP" ]; then
    exit 0
fi
/usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE\nHost: $HOSTNAME\nState: $HOSTSTATE\nAddress: $HOSTADDRESS\nInfo: $HOSTOUTPUT\n\nDate/Time: $LONGDATETIME\n" | /bin/mail -s "** $NOTIFICATIONTYPE Host Alert: $HOSTNAME is $HOSTSTATE **" $CONTACTEMAIL
exit 0
That should get you going.
SRSchnell
Post by SRSchnell »
Thanks ssax,
It mostly works. I added debug commands to find out what wasn't working. Is there any reason it won't seem to pass $CONTACTEMAIL$?
R
ssax
Dreams In Code
Post by ssax »
Hmm, maybe it doesn't like the @ symbol, try this:
       command_line                  		        /usr/local/nagios/libexec/host_notification_handler.sh $NOTIFICATIONTYPE$ $HOSTNAME$ $HOSTSTATE$ $LASTHOSTSTATE$ $HOSTADDRESS$ $HOSTOUTPUT$ $LONGDATETIME$ '$CONTACTEMAIL$'
#!/bin/bash
HOSTNAME="$2"
HOSTSTATE="$3"
LASTHOSTSTATE="$4"
HOSTADDRESS="$5"
HOSTOUTPUT="$6"
LONGDATETIME="$7"
CONTACTEMAIL="$8"
    exit 0
fi
/usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE\nHost: $HOSTNAME\nState: $HOSTSTATE\nAddress: $HOSTADDRESS\nInfo: $HOSTOUTPUT\n\nDate/Time: $LONGDATETIME\n" | /bin/mail -s "** $NOTIFICATIONTYPE Host Alert: $HOSTNAME is $HOSTSTATE **" '$CONTACTEMAIL'
exit 0
Let me know the results.
SRSchnell
Post by SRSchnell »
I get the following error in the nagios.log when things go down;
[1473169558] HOST NOTIFICATION: markw;test.switch;DOWN;notify-host-by-email-2;CRITICAL - Host Unreachable (192.168.0.10)
[1473169558] wproc: NOTIFY job 4 from worker Core Worker 21777 is a non-check helper but exited with return code 2
[1473169558] wproc: host=test.switch; service=(none); contact=markw
[1473169558] wproc: early_timeout=0; exited_ok=1; wait_status=512; error_code=0;
[1473169558] wproc: stderr line 01: /bin/sh: 1: Syntax error: "(" unexpected
and this upon recovery
8: NOTIFICATIONTYPE=RECOVERY
9: HOSTNAME=test.voip
10: HOSTSTATE=UP
11: LASTHOSTSTATE=UNREACHABLE
12: HOSTADDRESS=192.168.0.11
13: HOSTOUTPUT=PING
14: LONGDATETIME=OK
16: CONTACTEMAIL=-
These are the code snippets I'm using:
# 'notify-host-by-email-2' command definition
        command_name    notify-host-by-email-2
        command_line    /home/rod/host_notification_handler.sh $NOTIFICATIONTYPE$ $HOSTNAME$ $HOSTSTATE$ $LASTHOSTSTATE$ $HOSTADDRESS$ $HOSTOUTPUT$ $LONGDATETIME$ '$CONTACTEMAIL$' >>/home/rod/debug-nagios.txt
#!/bin/bash
exec 5> /home/rod/nagios-debug.txt
BASH_XTRACEFD="5"
PS4='$LINENO: '
set -x
HOSTNAME="$2"
HOSTSTATE="$3"
LASTHOSTSTATE="$4"
HOSTADDRESS="$5"
HOSTOUTPUT="$6"
LONGDATETIME="$7"
CONTACTEMAIL="$8"
echo $NOTIFICATIONTYPE
echo $HOSTNAME
echo $HOSTSTATE
echo $LASTHOSTSTATE
echo $HOSTADDRESS
echo $HOSTOUTPUT
echo $LONGDATETIME
echo $CONTACTEMAIL
    exit 0
fi
/usr/bin/printf "%b" "Subject: $NOTIFICATIONTYPE\n Service Alert: $HOSTALIAS/$SERVICEDESC is $SERVICESTATE\n\n***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE\n\nService: $SERVICEDESC\nHost: $HOSTALIAS\nAddress: $HOSTADDRESS\nState: $SERVICESTATE\n\nDate/Time: $LONGDATETIME\n\nAdditional Info: \n\n$SERVICEOUTPUT\n" | /usr/sbin/sendmail -vt '$CONTACTEMAIL'
exit 0
Could you post the contact definition for 'markw' for us to look at?
SRSchnell
Post by SRSchnell »
# Mark W
define contact{
        contact_name                         markw                      ; Short name of user
        use                                  generic-contact            ; Inherit default values from generic-contact template
        alias                                Mark W                     ; Full name of user
        email                                [email protected]  ; email address
        host_notifications_enabled           1
#        host_notification_options            d,r
        host_notification_commands           notify-host-by-email-2
Try changing the notify-host-by-email-2 command from
to
        command_line    /home/rod/host_notification_handler.sh $NOTIFICATIONTYPE$ "$HOSTNAME$" $HOSTSTATE$ $LASTHOSTSTATE$ "$HOSTADDRESS$" "$HOSTOUTPUT$" "$LONGDATETIME$" "$CONTACTEMAIL$" >>/home/rod/debug-nagios.txt
Restart Nagios and see if that fixes it.
Some of the output to the macros will have spaces and other characters that could be causing the problem, and the double quotes will fix that.
If not, can you post your generic-contact template?
SRSchnell
Post by SRSchnell »
That fixed the problem (other than formatting errors on my part ;) )!
Can you expand upon the explanation of the difference between single quotes and double quotes?
Thanks for all the help!
Rod
Re: Suppress Notification of UP after UNREACHABLE (FIXED!)
Post by mcapra »
It's likely that there was some escaping that needed to be done at the CLI level that single quotes was not able to tackle.
