issue with database
issue with database
Hi There!
Im pretty new to nagios and I am running into this issue everytime I try to login to the webpage.
Request you to kindly advise me on how to troubleshoot the same.
Thank you,
A
Thank you,
A
Re: issue with database
Have you tried running the script mentioned on that page from the CLI?
/usr/local/nagiosxi/scripts/repair_databases.shFormer Nagios employee
Hi there,
Yes I did run the script .. but it didnt work and I am encountering the same issue. Please let me know what is the best way to resolve it.
Thank you
Thank you
Can you share the output of that script? Also share the output of the following:
ls -al /usr/local/nagiosxi/scripts/Former Nagios employee
Hi there
here is the screenshot for : ls -al /usr/local/nagiosxi/scripts/
Please let me know how to proceed.
Than you
Than you
Please remove the repair_databases.lock file and run the script again:
rm /usr/local/nagiosxi/scripts/repair_databases.lock
Hi There,
So I ran the commands you asked me to run but ran into the following issue.
Please let me know how I can proceed next.
Thank you
Thank you
Strange that there are no myi files in that directory. Share the output of:
ls -al /var/lib/mysql/nagios
ls -al /var/lib/mysql/nagiosql
ls -al /var/lib/mysql/nagiosxi
Hi there,
I ran the commands as instructed by you, here is the output of it..please let me know the next best step,
Thank you
[root@nagios ~]# ls -al /var/lib/mysql/nagios
total 8
drwxr-xr-x 2 root root 4096 Mar 17 15:29 .
drwxr-xr-x. 4 mysql mysql 4096 Aug 31 14:36 ..
[root@nagios ~]# ls -al /var/lib/mysql/nagiosql
total 8
drwxr-xr-x 2 root root 4096 Mar 17 15:32 .
drwxr-xr-x. 4 mysql mysql 4096 Aug 31 14:39 ..
[root@nagios ~]# ls -al /var/lib/mysql/nagiosxi
ls: cannot access /var/lib/mysql/nagiosxi: No such file or directory
Thank you
total 8
total 8
It looks like you're missing some important files for your MySQL databases.
Please follow this KB article for instructions on how to restore them from a backup:
https://support.nagios.com/kb/article.php?id=492
If you don't know of any backups in existence, you might refer to the "Emergency Restore" section.
