[quote]
Waiting for Database Startup
It looks like your local elasticsearch service is starting.
Why am I getting this error?
Elasticsearch can take a little while to start up because of it's indexing. This may take a few seconds.
The page will refresh automatically after 5 seconds...
[/code]
I checked the logstash.log and found this:
[2016-08-31 16:23:18,420][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
[2016-08-31 16:23:21,640][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
[2016-08-31 16:23:24,858][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
[2016-08-31 16:23:28,077][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
[2016-08-31 16:23:31,296][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
[2016-08-31 16:23:31,347][DEBUG][action.admin.indices.create] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] observer: timeout notification from cluster service. timeout setting [1m], time since start [1m]
[2016-08-31 16:23:31,478][DEBUG][action.admin.indices.create] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] observer: timeout notification from cluster service. timeout setting [1m], time since start [1m]
[2016-08-31 16:23:31,482][DEBUG][action.admin.indices.create] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] no known master node, scheduling a retry
[2016-08-31 16:23:31,526][DEBUG][action.admin.cluster.state] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] observer: timeout notification from cluster service. timeout setting [30s], time since start [30s]
[2016-08-31 16:23:31,606][DEBUG][action.admin.indices.create] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] no known master node, scheduling a retry
[2016-08-31 16:23:34,514][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
[2016-08-31 16:23:37,732][INFO ][discovery.zen ] [6a7ce4ea-e1b9-47a1-af18-1c4d47243d20] failed to send join request to master [[636f559a-1fd5-4158-9dee-92e1a8403a1e][GkzwBa-QTHCOKiuoWgmR8Q][localhost][inet[/127.0.0.1:9300]]{max_local_storage_nodes=1}], reason [RemoteTransportException[[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][inet[/127.0.0.1:9300]][internal:discovery/zen/join]]; nested: ElasticsearchIllegalStateException[Node [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}] not master for join request from [[6a7ce4ea-e1b9-47a1-af18-1c4d47243d20][0XjhXD2VRp6K3k8Eq4UDlQ][sa585][inet[/172.27.164.109:9300]]{max_local_storage_nodes=1}]]; ], tried [3] times
