Quick Action using Free Variable - not substituting
SteveBeauchemin
Post by SteveBeauchemin »
In the Quick Action setup I am trying to use Free Variables. The code under the covers looks like it supports use of Free Variables, but I have not been able to find the magic syntax to make it work yet.
If I use %hostid% it provides me with 134 and that is good.
If I use %hoststatustext% is shows me "OK - 127.0.0.1: rta 0.691ms, lost 0%" also good.
But a Free Variable such as %_HOSTOWNER% shows me %_HOSTOWNER% and not the content of the Free Variable.
I have tried using _OWNER _HOSTOWNER %_OWNER% %_HOSTOWNER% $_OWNER$ $_HOSTOWNER$
All I get back are the same exact name. No variable substitution.
Help?
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Re: Quick Action using Free Variable - not substituting
Try using %_HOSTHOSTOWNER% in the actions component.
SteveBeauchemin
I figured it out.
The Underscore stuff caught me.
The actual variable = __OWNER_POC
2 underscores in front
I use it like this %_HOST_OWNER_POC%
and it works. I'm not sure what rabbit hole I went down, but I'm good now.
Thanks.
Steve B
...close the issue please.
Post by mcapra »
Thanks for sharing your solution! Closing this up
