I have an issue with setting up scheduled downtime at one of our newest sites. The command that our sript is using is (I have changed the password for the post)
This works at one of our existing setups. I checked to see if there is a restart user in the .htaccess file and there is not at the site that this command currently works on. So I am confused as to where else to check to see where this user may be located. I see the commands in the nagios.log on the server that this is not working on but I don't see any errors.
Is there be some configuration variable that I need to look at?
Reason:Please use [code][/code] tags around code or terminal commands
