Logstash service not running. Reboot did not correct
krobertson71
Post by krobertson71 »
Reboot the service did not correct. I can see one error:
The Logstash.log file says it was created on August 25th but contains no data.
This is a service down situation.
Re: Logstash service not running. Reboot did not correct
Post by mcapra »
Can you share the full output of:
/usr/local/nagioslogserver/logstash/bin/logstash -f /usr/local/nagioslogserver/logstash/etc/conf.d
krobertson71
Here is the output. After running this I can see many events now flowing into NLS and filling in the last few days as well. In the GUI it still shows the log stash service as RED.
Sep 06, 2016 11:13:25 AM org.elasticsearch.plugins.PluginsService <init>
INFO: [b2733b10-233a-4593-9428-85145cd54c77] loaded [], sites []
Logstash startup completed
Sep 06, 2016 11:13:27 AM org.elasticsearch.plugins.PluginsService <init>
Received an event that has a different character encoding than you configured. {:text=>"<13>Sep  4 20:46:39 10.0.101.35 \\xA6\\u0003\\n", :expected_charset=>"UTF-8", :level=>:warn}
krobertson71
Also note the we are running a two cluster node. The log stash server on 02 is fine, but 01 is the primary collector.
Post by mcapra »
That's good news then that logstash isn't encountering any fatal errors.
Can you share the output of the following:
service logstash restart
As well as the contents of the following file:
/etc/init.d/logstash
Be sure that the previously started logstash instance is not still running.
krobertson71
service logstash restart:
sudo /etc/init.d/logstash restart
Restarting Logstash Daemon:                                [FAILED]
WARNING: Default JAVA_OPTS will be overridden by the JAVA_OPTS defined in the environment. Environment JAVA_OPTS are -Djava.io.tmpdir=/usr/local/nagioslogserver/tmp
                                                           [  OK  ]
[nagios@nagilgp01 nagioslogserver_log]$ Sep 06, 2016 12:16:00 PM org.elasticsearch.plugins.PluginsService <init>
Sep 06, 2016 12:16:01 PM org.elasticsearch.plugins.PluginsService <init>
cat /etc/init.d/logstash
#! /bin/sh
#       /etc/rc.d/init.d/logstash
#       Starts Logstash as a daemon
# chkconfig: 2345 90 10
# description: Starts Logstash as a daemon.
### BEGIN INIT INFO
# Provides: logstash
# Required-Start: $local_fs $remote_fs
# Required-Stop: $local_fs $remote_fs
# Default-Start: 2 3 4 5
# Default-Stop: S 0 1 6
# Short-Description: Logstash
# Description: Starts Logstash as a daemon.
### END INIT INFO
. /etc/rc.d/init.d/functions
NAME=logstash
DESC="Logstash Daemon"
DEFAULT=/etc/sysconfig/$NAME
if [ `id -u` -ne 0 ]; then
   echo "You need root privileges to run this script"
   exit 1
fi
# The following variables can be overwritten in $DEFAULT
PATH=/bin:/usr/bin:/sbin:/usr/sbin
# See contents of file named in $DEFAULT for comments
LS_USER=logstash
LS_GROUP=logstash
LS_HOME=/usr/local/nagioslogserver
LS_HEAP_SIZE="500m"
LS_JAVA_OPTS="-Djava.io.tmpdir=${LS_HOME}/tmp"
LS_LOG_FILE=/var/log/logstash/$NAME.log
LS_CONF_DIR=/etc/logstash/conf.d
LS_OPEN_FILES=16384
LS_NICE=19
LS_OPTS=""
LS_PIDFILE=/var/run/$NAME/$NAME.pid
LS_PIDDIR=/var/run/$NAME
# End of variables that can be overwritten in $DEFAULT
if [ -f "$DEFAULT" ]; then
  . "$DEFAULT"
fi
# Define other required variables
PID_FILE=${LS_PIDFILE}
# Make sure the pid directory actually exists (CentOS/RHEL 7)
if [ ! -d $LS_PIDDIR ]; then
   install -d -m 0755 -o $LS_USER -g $LS_USER $LS_PIDDIR
fi
DAEMON="$LS_HOME/bin/logstash"
DAEMON_OPTS="agent -f ${LS_CONF_DIR} -l ${LS_LOG_FILE} ${LS_OPTS}"
# Function that starts the daemon/service
do_start()
  if [ -z "$DAEMON" ]; then
    echo "not found - $DAEMON"
    exit 1
  fi
  if pidofproc -p "$PID_FILE" >/dev/null; then
    failure
    exit 99
  fi
  # Prepare environment
  HOME="${HOME:-$LS_HOME}"
  JAVA_OPTS="${LS_JAVA_OPTS}"
  ulimit -n ${LS_OPEN_FILES}
  cd "${LS_HOME}"
  export PATH HOME JAVA_OPTS LS_HEAP_SIZE LS_JAVA_OPTS LS_USE_GC_LOGGING
  test -n "${JAVACMD}" && export JAVACMD
  nice -n ${LS_NICE} runuser -s /bin/sh -c "exec $DAEMON $DAEMON_OPTS" ${LS_USER} > /dev/null 1>&1 < /dev/null &
  RETVAL=$?
  local PID=$!
  # runuser forks rather than execing our process.
  usleep 500000
  JAVA_PID=$(ps axo ppid,pid | awk -v "ppid=$PID" '$1==ppid {print $2}')
  PID=${JAVA_PID:-$PID}
  echo $PID > $PID_FILE
  chown $LS_USER:$LS_GROUP $PID_FILE
  [ $PID = $JAVA_PID ] && success
# Function that stops the daemon/service
do_stop()
    killproc -p $PID_FILE $DAEMON
    RETVAL=$?
    echo
    [ $RETVAL = 0 ] && rm -f ${PID_FILE}
case "$1" in
  start)
    echo -n "Starting $DESC: "
    do_start
    touch /var/run/logstash/$NAME
  stop)
    echo -n "Stopping $DESC: "
    do_stop
    rm /var/run/logstash/$NAME
  restart|reload)
    echo -n "Restarting $DESC: "
    do_stop
    do_start
  status)
    echo -n "$DESC"
    status -p $PID_FILE
    exit $?
    echo "Usage: $SCRIPTNAME {start|stop|status|restart}" >&2
    exit 3
esac
echo
exit 0
What are the permissions on these files?
ls -la /var/run/logstash/logstash.pid
ls -la /var/run/elasticsearch/elasticsearch.pid
Additionally, what happens if you attempt to load both of these pages from your browser? (replace x.x.x.x with the hostname / IP you're trying to access with).
http://x.x.x.x/nagioslogserver/api/system/status?subsystem=elasticsearch
http://x.x.x.x/nagioslogserver/api/system/status?subsystem=logstash
Finally, do you have anything in front of the two NLS machines?
krobertson71
Actually it is now all green. The api call shows Logstash is up and running. It just took a really long time to "Green Up".
This command you had me run is what started the data flowing in again.
I am assuming that was a reinitializing of the logstash service.
Thanks for the help.
Post by mcapra »
If the aforementioned pid files have incorrect permissions, this would explain why the init.d script is failing. There could also be some math in terms of allocating the memory available to Java that is done within the init.d file.
You can certainly run the logstash binary directly every time (as I detailed in my previous post), but the stock NLS environment is going to try to start logstash via the init.d script every time the system reboots.
Post by mcapra »
Lets see what the following commands give us:
service logstash stop
service logstash start
