Hello XI Support
What is the default password for nagios user after Linux Agent install on Linux computer
(it is OK to change one?)
Thank you
nagios user default password
Re: nagios user default password
I don't believe there is a default password at all. Yes, it's OK to change it, just make sure you update your checks accordingly if you specify one.
Thank yourkennedy wrote:I don't believe there is a default password at all. Yes, it's OK to change it, just make sure you update your checks accordingly if you specify one.
Please close
