Nagiosmobile passwords
So, where is nagiosmobile getting the authentication from? I login to nagiosmobile with my original password for XI. We have since changed to AD authentication and I'd love for nagiosmobile to use those same credentials, is that not possible?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Nagiosmobile passwords
# cat /etc/httpd/conf.d/nagiosmobile.conf
#modify this file to fit your apache configuration
Alias /nagiosmobile "/usr/local/nagiosmobile"
<Directory "/usr/local/nagiosmobile">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Allow from 127.0.0.1
######use the below lines for Nagios XI
# AuthName "Nagios Monitor XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
######Use the below lines for a SOURCE install of Nagios Core
AuthName "Nagios Access"
AuthType Basic
AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
</Directory>
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
AuthType Basic
# AuthName "Nagios Access"
# AuthType Basic
# AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
</Directory>
That file was updated ~23 hours ago on our test XI system. I assume that there's some thing in XI that populates the file when "apply changes" are made.
All of the users in "htpasswd.users" should be able to log in nagiosmobile via basic auth.
awk -F ':' '{print $1}' /usr/local/nagiosxi/etc/htpasswd.usersBe sure to check out our Knowledgebase for helpful articles and solutions!
So what password would that use? What happens for users we import from AD?lmiltchev wrote:All of the users in "htpasswd.users" should be able to log in nagiosmobile via basic auth.Code: Select all
The htpasswd file is updated with whatever password is used to login EVERY time the user logs in. When you initially import or create the user the htpasswd entry is only put into the htpasswd file on the first login and then will be updated on every successful login thereafter.
So it should use the AD password as long as they logged into the XI interface with that AD password before.
Aw, sweet! That actually helps me with a customer issue!
BanditBBS, can we lock this topic?
Ludmil, so shouldn't the file have a date/time equal to the last time someone logged into XI?
-rw-r--r-- 1 nagios apache 4970 Aug 15 2015 /usr/local/nagiosxi/etc/htpasswd.users2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
