Hi
i've just upgraded my NagiosXi from 1.7 to 1.8 and i had several warning at the end of the setup. I would like if i must take in consideration these warning or not ??? but my Nagios server seems to be working properly ....
Bye and thx in advance.
Upgrade from 1.7 to 1.8 warning
Re: Upgrade from 1.7 to 1.8 warning
Those warning are just config warning so you'll probably be ok. Does Nagios start up correctly and run properly? If so then they should be ok.
Nicholas Scott
yes everything seems to be working properly ...
Please, let us know if you run into some issues. We appreciate users' feedback. It helps us a lot with troubleshooting and fixing bugs.
for the time beeing, no side effects ... detected ... maybe in the futur..i let you know ..
