Check disk alerts for all hosts at the same time
vannessa.ochoa
Post by vannessa.ochoa »
Hi Everyone,
I am looking for set up Nagios Core to get check_disk notifications for all my hosts at the same time (ex. 9am every day). Is that possible?
I have created a separated service for check_disk and now this service is sending notifications every 12 hours, but I need to sync all host to run at the same time.
Hopefully you can help me.
Thank you,
Vannessa Ochoa
Re: Check disk alerts for all hosts at the same time
To be sure, you want to run the check once a day, correct?
If so, take a look at this post for a possible solution.
https://support.nagios.com/forum/viewto ... 7&t=25216#
You can't set it to run exactly at 9am but you can do a small window around 9am.
Let us know is this is what you are looking for.
