NNA installation issue
ls4074
Post by ls4074 »
I am trying to install NNA to do some POC, but I got the following errors:
#./fullinstall
Nagios Network Analyzer Installation
DATE: Fri Sep 16 10:13:59 PDT 2016
DISTRO INFO:
RedHatEnterpriseServer
6.5
x86_64
Running 'prereqs'...
HELLO0
Enabling epel repo...
6
curl: (7) couldn't connect to host
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
Re: NNA installation issue
Does this machine have an Internet connection? It looks like it is not able to reach out.
Also, please include the install.log file as indicated in the error output.
ls4074
Post by ls4074 »
Hello Trevor,
Sorry, I didn't see your reply until now (I didn't get notification when response is posted. Just learned I can set the notification).
Yes, this machine has Internet connection. I can ping yahoo.com from this machine.
here is the content on the install.log
[ls4074@olph171 nagiosna]$ sudo cat install.log
DATE: Tue Sep 13 13:29:40 PDT 2016
DISTRO INFO:
6.5
x86_64
6
INSTALLATION ERROR!
[ls4074@olph171 nagiosna]$ ping yahoo.com
PING yahoo.com (98.138.253.109) 56(84) bytes of data.
64 bytes from ir1.fp.vip.ne1.yahoo.com (98.138.253.109): icmp_seq=1 ttl=45 time=93.3 ms
64 bytes from ir1.fp.vip.ne1.yahoo.com (98.138.253.109): icmp_seq=2 ttl=45 time=83.0 ms
64 bytes from ir1.fp.vip.ne1.yahoo.com (98.138.253.109): icmp_seq=3 ttl=45 time=74.3 ms
Post by Box293 »
What is the output of this command:
curl -L -O https://assets.nagios.com/epel/epel-release-latest-6.noarch.rpm
ls4074
Post by ls4074 »
Here is what I got for the curl command:
[ls4074@olph171 ~]$ curl -L -O https://assets.nagios.com/epel/epel-rel ... noarch.rpm
however, On my pc, I could access the above URL.
Thanks!
bwallace
Post by bwallace »
OK, let us know if you still have install issues after confirming the machine has internet access. Please be sure to post the install log - thanks -
ls4074
Post by ls4074 »
The "curl: (7) couldn't connect to host" issue was caused by a proxy setting. I have fixed that. The install went quite a lot, but at the end, it gave errors. Please see the install.log in the attachment.
Thanks!
It looks like the proxy server blocked a file from being downloaded correctly.
We have a KB article for setting is a Nagios XI server for a proxy that you can use on the NNA server. Take a look at it and see if following through it, fixes the issue.
https://support.nagios.com/kb/article.php?id=147
ls4074
Post by ls4074 »
I have updated the /etc/yum.conf and /etc/wgetrc to use the http_proxy server. However, still get the error. Please see the install.log in the attachment. I am wondering if we can get the required rpm packages and we will install them separately before we run fullinstall.
Thanks!
The step that failed was: 'wkhtmltopdf'
I suspect that you have a few copies (some probably corrupted) of the "wkhtmltox-0.12.2.1_linux-centos6-amd64.rpm" package downloaded, i.e. "wkhtmltox-0.12.2.1_linux-centos6-amd64.rpm.2"... because initially you didn't have your proxy configured properly. Try installing the package manually by running the following command:
rpm -Uvh /path/to/wkhtmltox-0.12.2.1_linux-centos6-amd64.rpm
