Log or database entry for host changing host group?
peter.zanetti
Post by peter.zanetti »
We frequently have hosts that change host groups to receive different types of monitoring, is there anywhere we can see when a host was moved from one host group to another?
Re: Log or database entry for host changing host group?
Post by mcapra »
If I remove the host "alice" from the hostgroup "mediocre-servers" and add it to the hostgroup "cool-servers", the following entry is added to nagiosxi.xi_auditlog.message:
Host modified: alice
So not exactly as specific as you would like.
You could probably do this on a cron job by querying the nagiosql.tbl_host table and storing the entries id, host_name, and hostgroups fields and using them as a reference for the next time the cron job gets run. Some pseudocode:
$old = previous query result;
$current = SELECT id, host_name, hostgroups FROM nagiosql.tbl_host;
if(!($old.hostgroups == $current.hostgroups)) {
    //changes were made, figure them out and report to a file
