Thanks for your replying. My hosts, services and command.
My host:
# Host configuration file
# Created by: Nagios QL Version 3.2.0
# Date: 2017-01-02 13:18:56
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
define host {
host_name _UDP-C
alias 4F UDP-C
address 172.16.x.x
use xxx-server
contacts nagiosadmin
register 1
# END OF FILE
My service:
# Service configuration file
# Date: 2017-01-02 13:18:57
#NAGIOSQL_CONFIG_NAME imp_n6t4-UDPC
host_name _UDP-A
service_description Current UDP C
display_name Current UDP C
use generic-env832-device
check_command check_current_pmm_udp!21!0!1100
passive_checks_enabled 1
register 1
# END OF FILE
You will want to modify the python script to have a longer timeout as @Box293 mentioned, or debug why that variable is happening. This isn't a standard plugin, so we're limited on the help we can provide for it.
