Is there a limit to the number of dashboards that are displayed in the home screen, log server overview?
I have 5 dashboards saved:
Then I select Load/advanced/browse find the new dashboard, "VPN_Sessions" load it and save it:
as you can see the new dashboard is saved but NLS has removed the "Application crashes" dashboard and replaced it with "VPN Sessions".
I have flushed the browser cache, and am running the latest version of NLS.
How to I make NLS show more than 5 dashboards?
dashboard sidplays a max of five items
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: dashboard sidplays a max of five items
Did you click 'save' or 'save as'? I filed a feature request recently, as I noticed that it would overwrite whichever dashboard you were on, if you did not click 'save as'.
I just tested on my system, and have 6 dashboards showing without an issue.
save as did it. but...and i never thought I would say this of anything you guys made..actually, never mind. I'm all set. you can lock it up, thanks.
Proudly running:
Nagios Fusion
Nagios Fusion
