Hi team,
I have created views for different team (windows,Unix,Network).Now I want to deploy this views to the users but there is no options in Nagios XI like the one we had to deploy dashboards.Could please suggest way so I could deploy to multiple users.
How to import/deploy Views
gselvakumar
Thanks & Regards,
Gomathyshankar Selvakumar
Re: How to import/deploy Views
There is no way to share views with other users. You could apply your desired view to a dashboard then deploy that dashboard with another user. Or, you could copy the URL of a view, send that to your user(s) and they can manually create the view themselves using that url. Of course this is not very realistic when numerous users are involved.
I submitted a feature request to add the ability to share / deploy views with other users TASK ID 9572
gselvakumar
Hi bwallace,
Thanks for the update.
Thanks & Regards,
Since there is a feature request in place, I will be closing this thread. Keep an eye on the changelogs for future releases!
