Maintenace Downtime
Maintenace Downtime
HI,
Is there a way to place a host/service on a scheduled downtime via shell?
The reason I'm asking is because we have scripts to restart apps/servers and we wanted to incorporate placing these host/service on a scheduled maintenance mode within the script.
Thanks in advanced.
Thanks in advanced.
Re: Maintenace Downtime
Thanks mguthrie.
Do you think you could give me an example of scheduling a downtime for host (advdprint1) from 10 am to 1130 am? I know the examples show exactly how to do it but unfortunately, I am not an expert when it comes to scripting.
Again, thank you for your help.
#!/bin/sh
now=`date +%s`
dtCommand=SCHEDULE_HOST_DOWNTIME
pipe='/usr/local/nagios/var/rw/nagios.cmd'
#start= ?? ##You'll have to figure out how to calculate your start and end time, needs to be an epoch timestamp
#end = ?? ##
duration=5400 #90 minutes
username=mguthrie
message="This host is in scheduled downtime"
host=advdprint1
/bin/echo "[$now] $dtCommand;$host;$start;$dtEnd;1;0;$duration;$username;$message" > $pipeRe: Maintenace Downtime
I'm guessing I would paste the sample script to a new file.
What file do I name it to? Sorry for asking these kind questions but I'm also new to Linux.
Thanks in advanced.
Thanks in advanced.
Have the following copied to test.sh file and executed the file from /usre/local/nagios/var/rw and received no results. The server did not go to maintenance mode. Please advise. Thanks.
#!/bin/sh
now=`date +%s`
#start=1332501306 ##You'll have to figure out how to calculate your start and end time, needs to be an epoch timestamp
#end =1332504906 ##
duration=3600 #60 minutes
username=tgfde
host=epmqowcs3
#!/bin/sh
now=`date +%s`
#end =1332504906 ##
username=tgfde
host=epmqowcs3
This was pretty close, you need to remove the # before the start and end lines (# is a comment)
Also we did have an error in the last line I modified.
Make it something like this changing the numbers after start and end to correct times...
#!/bin/sh
now=`date +%s`
start=1332501306
end=1332504906
username=tgfde
host=epmqowcs3
/bin/echo "[$now] $dtCommand;$host;$start;$end;1;0;$duration;$username;$message" > $pipeRe: Maintenace Downtime
Oops...I can't believe I missed the # comment before the start and end lines.
Anyway I tried it again with the following command and it didn't work....
#!/bin/sh
now=`date +%s`
start=1332522000
end=1332525600
username=tgfde
host=epmqowcs3
Thanks.
#!/bin/sh
now=`date +%s`
start=1332522000
end=1332525600
username=tgfde
host=epmqowcs3
Thanks.
First, set the following items in your /usr/local/nagios/etc/nagios.cfg file if they're not already set like this:
Then run:
to watch the Nagios log. If the command submission doesn't work there should be some info in there to point to the problem.
check_external_commands=1
log_external_commands=1Code: Select all
tail -f /usr/local/nagios/var/nagios.logRe: Maintenace Downtime
It looks like it did put the host on a scheduled down time but I don't see it in the UI. Thanks.
[root@cordmon1 rw]# tail -f /usr/local/nagios/var/nagios.log
[1333134710] Event broker module '/usr/local/nagios/bin/ndomod.o' deinitialized successfully.
[1333134710] Nagios 3.2.3 starting... (PID=25262)
[1333134710] Local time is Fri Mar 30 14:11:50 CDT 2012
[1333134710] LOG VERSION: 2.0
[1333134710] ndomod: NDOMOD 1.4b9 (10-27-2009) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1333134710] ndomod: Successfully connected to data sink. 0 queued items to flush.
[1333134710] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
[1333134710] Finished daemonizing... (New PID=25265)
[1333134794] EXTERNAL COMMAND: SCHEDULE_HOST_DOWNTIME;epmqowcs3;1332522000;1332525600;1;0;3600;tgfde;This host is in scheduled downtime
[1333134973] EXTERNAL COMMAND: SCHEDULE_HOST_DOWNTIME;epmqowcs3;1333117800;1333121400;1;0;3600;tgfde;This host is in scheduled downtime
