Hi Nagios Support,
I'm hoping someone can help me here. I am running nagios 4.2.0 on RHEL 7 box. I was looking for a config tool and cam across nagiosql as probably one of the only ones recommended for core 4.
Ive gone through the installation fine, however when I get to the login page for nagiosql I get a DB connection error, and I cannot login. Error below -
"Error while connectiong to database [localhost] Connection to the database server has failed by reason: Accessed denied for user 'nagiosql_user'@'localhost' (using password: YES)"
I am running the web UI install on the box itself, hence "localhost", but I have tried running from an external browser specifying either the IP or FQHN.
Running mariaDB server 5.5.50. I can log into the DB locally with the nagiosql user, using the mysql console.
Everything checks out on the pre-install steps so I am confused by this one.
Has anyone experienced the same?
At this stage I am also open to trying a different config tool - I just haven't found one for version 4.2.0
Any help/insight much appreciated.
Nagiosql MySQL DB connection error
Re: Nagiosql MySQL DB connection error
You mention that 'nagiosql' works to log in to the database, but the access denied is for 'nagiosql_user'. I would take a look at configuration files to make sure you're passing the right credentials.
Just so you know, NagiosQL isn't our product so we're a bit limited on the support we can provide.
Thanks for your reply.
Yes I checked the config file and it looks like the information passed is ok.
Your point led me down the road of credential issues.
I was able to resolve this in a rather strange way. I was setting the db user password (nagiousql_user), to be the same as the nagiosql admin user (admin). I ran the install again and gave unique passwords for both, and things went ok.
Thanks for your help.
No problem, those little things get us all at times. Glad to see you resolved the issue!
Going to close this one up.
