just wondering, what mount command can i use to mount a windows share to check i the files are sitting there longer then 5 minutes ?
or example - I need to check files in a server \\10.1.136.130\c:\interface\in
any files sitting more then 5 minutes need to create an alert
I will need to provide a user name and password
please email me at [email protected]
if there is a solution to this
Thank you.
need to mount a windows hidden share
Re: need to mount a windows hidden share
We don't generally email solutions, but I'll post a response here for which we can work through.
You can us NSClient++ in conjunction with this plugin - https://exchange.nagios.org/directory/P ... bs/details
I believe it's exactly what you're looking for.
