NRPE 3 and security
WillemDH
NRPE 3 and security
Post by WillemDH »
Can someone confirm the following security issue has been fixed in NRPE 3.x?
http://legalhackers.com/advisories/nagios-nrpe.txt
https://www.tenable.com/plugins/index.p ... e&id=73757
Tx
Willem
Nagios XI 5.8.1
https://outsideit.net
Re: NRPE 3 and security
I just tested this out, and although it did work on 2.15 it did not on NRPE v3. With allow_bash_command_substitution on it is a security risk regardless though.
[root@localhost libexec]# ./check_nrpe -H 192.168.47.4 -c check_users -a "`echo -e "\x0a touch /tmp/vulntest "` #" 4
CHECK_NRPE: Received 0 bytes from daemon.  Check the remote server logs for error messages.
NRPE vnrpe-3.0
Output from client side -
Sep 23 09:48:11 localhost nrpe[25099]: Error: Request contained illegal metachars!
Sep 23 09:48:11 localhost nrpe[25099]: Client request from 192.168.3.115 was invalid, bailing out...
NRPE 2.15 -
[root@localhost libexec]# ./check_nrpe -H 127.0.0.1 -c check_users -a "`echo -e "\x0a touch /tmp/vulntest "` #" 4
Usage:
check_users -w <users> -c <users>
NRPE v2.15
Sep 23 10:57:08 localhost xinetd[1264]: START: nrpe pid=32185 from=::ffff:127.0.0.1
Sep 23 10:57:08 localhost xinetd[1264]: EXIT: nrpe status=0 pid=32185 duration=0(sec)
Here is what is provided with NRPE regarding command substitution -
# BASH COMMAND SUBTITUTION
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments that contain bash command substitutions of the form
# $(...).  This option only works if the daemon was configured with both
# the --enable-command-args and --enable-bash-command-substitution configure
# script options.
# *** ENABLING THIS OPTION IS A HIGH SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow bash command substitutions,
#         1=allow bash command substitutions
SECURITY.md -
root@localhost:/tmp/nrpe-3.0# cat SECURITY.md
NRPE SECURITY README
### TCP WRAPPER SUPPORT ###
NRPE 2.x includes native support for TCP wrappers. Once you
compile NRPE you can check to see if it has wrapper support
built in by running the daemon from the command line without
any arguments like this:
        ./nrpe --help
#### COMMAND ARGUMENTS ####
NRPE 2.0 includes the ability for clients to supply arguments to
commands which should be run.  Please note that this feature
should be considered a security risk, and you should only use
it if you know what you're doing!
#### BASH COMMAND SUBSTITUTION ####
Even with the metacharacter restrictions below, if command arguments
are enabled, it is still possible to send bash command substitutions
in the form `$(...)` as an argument. This is explicitly disabled by
default, but can be enabled by a configure-time option and a
configuration file option. Enabling this option is **VERY RISKY**
and its use is **HIGHLY DISCOURAGED**.
#### ENABLING ARGUMENTS ####
To enable support for command argument in the daemon, you must
do two things:
   1.  Run the configure script with the `--enable-command-args`
       option
   2.  Set the `dont_blame_nrpe` directive in the NRPE config
       file to `1`.
#### ENABLING BASH COMMAND SUBSTITUTION ####
To enable support for arguments containing bash command substitions,
you must do two things:
   1.  Enable arguments as described above
   2.  Include the `--enable-bash-command-substitution` configure
       option when running the configure script
   3.  Set the `allow_bash_command_substitutions` directive in the
       NRPE config file to `1`.
#### ILLEGAL METACHARS ####
To help prevent some nasty things from being done by evil
clients, the following metacharacters are not allowed
in client command arguments:
Any client request which contains the above mentioned metachars
is discarded.
#### USER/GROUP RESTRICTIONS ####
The NRPE daemon cannot be run with (effective) root user/group
privileges.  You must run the daemon with an account that does
not have superuser rights.  Use the nrpe_user and nrpe_group
directives in the config file to specify which user/group the
daemon should run as.
#### ENCRYPTION ####
If you do enable support for command arguments in the NRPE daemon,
make sure that you encrypt communications either by using:
   1.  Stunnel (see http://www.stunnel.org for more info)
   2.  Native SSL support (See the `README.SSL.md` file for more info)
*Do NOT* assume that just because the daemon is behind a firewall
that you are safe!  Always encrypt NRPE traffic!
#### USING ARGUMENTS ####
How do you use command arguments?  Well, lets say you define a
command in the NRPE config file that looks like this:
        command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
You could then call the check_nrpe plugin like this:
        ./check_nrpe -H <host> -c check_users -a 5 10
The arguments '5' and '10' get substituted into the appropriate
$ARGx$ macros in the command ($ARG1$ and $ARG2$, respectively).
The command that would be executed by the NRPE daemon would look
like this:
        /usr/local/nagios/libexec/check_users -w 5 -c 10
You can supply up to 16 arguments to be passed to the command
for substitution in $ARG$ macros ($ARG1$ - $ARG16$).
WillemDH
Post by WillemDH »
Guess this can be closed. Working on NRPE security through this thread for now: https://support.nagios.com/forum/viewto ... 16&t=42002
Nagios XI 5.8.1
