Performance graphs
jpipitone
Performance graphs
Post by jpipitone »
Good morning,
I imported my NagiosXI config to a new server. Also restored performance graph configs. I am not seeing any performance graphs. I've added a new host with a few services, but no graphs. I used to see an icon next to a service to view historical graph data. Any help on where to start troubleshooting would be great. Thank you!
Previous thread here (locked):
https://support.nagios.com/forum/viewto ... =6&t=40360
I've run these commands and here's the output:
[root@nagios ~]# ls /usr/local/nagios/var/spool/perfdata | wc -l
0
[root@nagios ~]# ls /usr/local/nagios/var/spool/checkresults | wc -l
0
[root@nagios ~]# tail -50 /usr/local/nagios/var/npcd.log
[09-22-2016 10:50:50] NPCD: npcd Daemon (0.4.14) started with PID=11798
[09-22-2016 10:50:50] NPCD: Please have a look at 'npcd -V' to get license information
[09-22-2016 10:50:50] NPCD: HINT: load_threshold is enabled - ('10.000000')
Re: Performance graphs
On the new host / services checks, can you open them up in the Details menu and go to the Advanced Tab and see if there is performance data in the Performance Data field?
Then, can you run the following commands as root and post the output?
ls /usr/local/nagios/var/spool/xidpe | wc -l
ps -ef --cols=300
tail -50 /usr/local/nagios/var/perfdata.log
jpipitone
Post by jpipitone »
I see this:
rta=0.228ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=0.262ms;;;; rtmin=0.200ms;;;;
Here is the output from those commands:
0
0
[root@nagios ~]# ls /usr/local/nagios/var/spool/xidpe | wc -l
0
0
0
[root@nagios ~]# ps -ef --cols=300
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 Sep22 ?        00:01:28 /usr/lib/systemd/systemd --switched-root --system --deserialize 21
root         2     0  0 Sep22 ?        00:00:00 [kthreadd]
root         3     2  0 Sep22 ?        00:00:02 [ksoftirqd/0]
root         5     2  0 Sep22 ?        00:00:00 [kworker/0:0H]
root         7     2  0 Sep22 ?        00:00:01 [migration/0]
root         8     2  0 Sep22 ?        00:00:00 [rcu_bh]
root         9     2  0 Sep22 ?        00:00:00 [rcuob/0]
root        10     2  0 Sep22 ?        00:00:00 [rcuob/1]
root        11     2  0 Sep22 ?        00:00:00 [rcuob/2]
root        12     2  0 Sep22 ?        00:00:00 [rcuob/3]
root        13     2  0 Sep22 ?        00:00:00 [rcuob/4]
root        14     2  0 Sep22 ?        00:00:00 [rcuob/5]
root        15     2  0 Sep22 ?        00:00:00 [rcuob/6]
root        16     2  0 Sep22 ?        00:00:00 [rcuob/7]
root        17     2  0 Sep22 ?        00:00:00 [rcuob/8]
root        18     2  0 Sep22 ?        00:00:00 [rcuob/9]
root        19     2  0 Sep22 ?        00:00:00 [rcuob/10]
root        20     2  0 Sep22 ?        00:00:00 [rcuob/11]
root        21     2  0 Sep22 ?        00:00:00 [rcuob/12]
root        22     2  0 Sep22 ?        00:00:00 [rcuob/13]
root        23     2  0 Sep22 ?        00:00:00 [rcuob/14]
root        24     2  0 Sep22 ?        00:00:00 [rcuob/15]
root        25     2  0 Sep22 ?        00:00:00 [rcuob/16]
root        26     2  0 Sep22 ?        00:00:00 [rcuob/17]
root        27     2  0 Sep22 ?        00:00:00 [rcuob/18]
root        28     2  0 Sep22 ?        00:00:00 [rcuob/19]
root        29     2  0 Sep22 ?        00:00:00 [rcuob/20]
root        30     2  0 Sep22 ?        00:00:00 [rcuob/21]
root        31     2  0 Sep22 ?        00:00:00 [rcuob/22]
root        32     2  0 Sep22 ?        00:00:00 [rcuob/23]
root        33     2  0 Sep22 ?        00:00:00 [rcuob/24]
root        34     2  0 Sep22 ?        00:00:00 [rcuob/25]
root        35     2  0 Sep22 ?        00:00:00 [rcuob/26]
root        36     2  0 Sep22 ?        00:00:00 [rcuob/27]
root        37     2  0 Sep22 ?        00:00:00 [rcuob/28]
root        38     2  0 Sep22 ?        00:00:00 [rcuob/29]
root        39     2  0 Sep22 ?        00:00:00 [rcuob/30]
root        40     2  0 Sep22 ?        00:00:00 [rcuob/31]
root        41     2  0 Sep22 ?        00:04:22 [rcu_sched]
root        42     2  0 Sep22 ?        00:02:36 [rcuos/0]
root        43     2  0 Sep22 ?        00:02:03 [rcuos/1]
root        44     2  0 Sep22 ?        00:02:03 [rcuos/2]
root        45     2  0 Sep22 ?        00:02:17 [rcuos/3]
root        46     2  0 Sep22 ?        00:00:00 [rcuos/4]
root        47     2  0 Sep22 ?        00:00:00 [rcuos/5]
root        48     2  0 Sep22 ?        00:00:00 [rcuos/6]
root        49     2  0 Sep22 ?        00:00:00 [rcuos/7]
root        50     2  0 Sep22 ?        00:00:00 [rcuos/8]
root        51     2  0 Sep22 ?        00:00:00 [rcuos/9]
root        52     2  0 Sep22 ?        00:00:00 [rcuos/10]
root        53     2  0 Sep22 ?        00:00:00 [rcuos/11]
root        54     2  0 Sep22 ?        00:00:00 [rcuos/12]
root        55     2  0 Sep22 ?        00:00:00 [rcuos/13]
root        56     2  0 Sep22 ?        00:00:00 [rcuos/14]
root        57     2  0 Sep22 ?        00:00:00 [rcuos/15]
root        58     2  0 Sep22 ?        00:00:00 [rcuos/16]
root        59     2  0 Sep22 ?        00:00:00 [rcuos/17]
root        60     2  0 Sep22 ?        00:00:00 [rcuos/18]
root        61     2  0 Sep22 ?        00:00:00 [rcuos/19]
root        62     2  0 Sep22 ?        00:00:00 [rcuos/20]
root        63     2  0 Sep22 ?        00:00:00 [rcuos/21]
root        64     2  0 Sep22 ?        00:00:00 [rcuos/22]
root        65     2  0 Sep22 ?        00:00:00 [rcuos/23]
root        66     2  0 Sep22 ?        00:00:00 [rcuos/24]
root        67     2  0 Sep22 ?        00:00:00 [rcuos/25]
root        68     2  0 Sep22 ?        00:00:00 [rcuos/26]
root        69     2  0 Sep22 ?        00:00:00 [rcuos/27]
root        70     2  0 Sep22 ?        00:00:00 [rcuos/28]
root        71     2  0 Sep22 ?        00:00:00 [rcuos/29]
root        72     2  0 Sep22 ?        00:00:00 [rcuos/30]
root        73     2  0 Sep22 ?        00:00:00 [rcuos/31]
root        74     2  0 Sep22 ?        00:00:00 [watchdog/0]
root        75     2  0 Sep22 ?        00:00:00 [watchdog/1]
root        76     2  0 Sep22 ?        00:00:01 [migration/1]
root        77     2  0 Sep22 ?        00:00:00 [ksoftirqd/1]
root        79     2  0 Sep22 ?        00:00:00 [kworker/1:0H]
root        80     2  0 Sep22 ?        00:00:00 [watchdog/2]
root        81     2  0 Sep22 ?        00:00:01 [migration/2]
root        82     2  0 Sep22 ?        00:00:00 [ksoftirqd/2]
root        85     2  0 Sep22 ?        00:00:00 [watchdog/3]
root        86     2  0 Sep22 ?        00:00:01 [migration/3]
root        87     2  0 Sep22 ?        00:00:03 [ksoftirqd/3]
root        90     2  0 Sep22 ?        00:00:00 [khelper]
root        91     2  0 Sep22 ?        00:00:00 [kdevtmpfs]
root        92     2  0 Sep22 ?        00:00:00 [netns]
root        93     2  0 Sep22 ?        00:00:00 [perf]
root        94     2  0 Sep22 ?        00:00:00 [writeback]
root        95     2  0 Sep22 ?        00:00:00 [kintegrityd]
root        96     2  0 Sep22 ?        00:00:00 [bioset]
root        97     2  0 Sep22 ?        00:00:00 [kblockd]
root        98     2  0 Sep22 ?        00:00:00 [md]
root       106     2  0 Sep22 ?        00:00:00 [khungtaskd]
root       107     2  0 Sep22 ?        00:00:00 [kswapd0]
root       108     2  0 Sep22 ?        00:00:00 [ksmd]
root       109     2  0 Sep22 ?        00:00:04 [khugepaged]
root       110     2  0 Sep22 ?        00:00:00 [fsnotify_mark]
root       111     2  0 Sep22 ?        00:00:00 [crypto]
root       119     2  0 Sep22 ?        00:00:00 [kthrotld]
root       121     2  0 Sep22 ?        00:00:00 [kmpath_rdacd]
root       122     2  0 Sep22 ?        00:00:00 [kpsmoused]
root       123     2  0 Sep22 ?        00:00:00 [ipv6_addrconf]
root       142     2  0 Sep22 ?        00:00:00 [deferwq]
root       174     2  0 Sep22 ?        00:00:01 [kauditd]
root       344     2  0 Sep22 ?        00:00:00 [scsi_eh_0]
root       348     2  0 Sep22 ?        00:00:00 [scsi_tmf_0]
root       353     2  0 Sep22 ?        00:00:00 [ata_sff]
root       356     2  0 Sep22 ?        00:00:00 [events_power_ef]
root       359     2  0 Sep22 ?        00:00:00 [ttm_swap]
root       376     2  0 Sep22 ?        00:00:00 [scsi_eh_1]
root       377     2  0 Sep22 ?        00:00:00 [scsi_tmf_1]
root       378     2  0 Sep22 ?        00:00:00 [scsi_eh_2]
root       379     2  0 Sep22 ?        00:00:00 [scsi_tmf_2]
root       403     2  0 Sep22 ?        00:00:00 [scsi_eh_3]
root       404     2  0 Sep22 ?        00:00:00 [scsi_tmf_3]
root       405     2  0 Sep22 ?        00:00:00 [scsi_eh_4]
root       406     2  0 Sep22 ?        00:00:00 [scsi_tmf_4]
root       409     2  0 Sep22 ?        00:00:00 [scsi_eh_5]
root       410     2  0 Sep22 ?        00:00:00 [scsi_tmf_5]
root       411     2  0 Sep22 ?        00:00:09 [usb-storage]
root       412     2  0 Sep22 ?        00:00:00 [scsi_eh_6]
root       413     2  0 Sep22 ?        00:00:00 [scsi_tmf_6]
root       414     2  0 Sep22 ?        00:00:16 [usb-storage]
root       419     2  0 Sep22 ?        00:00:00 [kworker/1:1H]
root       420     2  0 Sep22 ?        00:00:00 [kworker/0:1H]
root       466     2  0 Sep22 ?        00:00:00 [kdmflush]
root       467     2  0 Sep22 ?        00:00:00 [bioset]
root       478     2  0 Sep22 ?        00:00:00 [kdmflush]
root       479     2  0 Sep22 ?        00:00:00 [bioset]
root       492     2  0 Sep22 ?        00:00:00 [xfsalloc]
root       493     2  0 Sep22 ?        00:00:00 [xfs_mru_cache]
root       494     2  0 Sep22 ?        00:00:00 [xfs-buf/dm-0]
root       495     2  0 Sep22 ?        00:00:00 [xfs-data/dm-0]
root       496     2  0 Sep22 ?        00:00:00 [xfs-conv/dm-0]
root       497     2  0 Sep22 ?        00:00:00 [xfs-cil/dm-0]
root       498     2  0 Sep22 ?        00:00:00 [xfs-reclaim/dm-]
root       499     2  0 Sep22 ?        00:00:00 [xfs-log/dm-0]
root       500     2  0 Sep22 ?        00:00:00 [xfs-eofblocks/d]
root       501     2  0 Sep22 ?        00:00:24 [xfsaild/dm-0]
root       572     1  0 Sep22 ?        00:00:17 /usr/lib/systemd/systemd-journald
root       597     1  0 Sep22 ?        00:00:00 /usr/lib/systemd/systemd-udevd
root       599     1  0 Sep22 ?        00:00:00 /usr/sbin/lvmetad -f
root       627     2  0 Sep22 ?        00:00:00 [edac-poller]
root       647     2  0 Sep22 ?        00:00:00 [kipmi0]
root       660     2  0 Sep22 ?        00:00:00 [xfs-buf/sda1]
root       661     2  0 Sep22 ?        00:00:00 [xfs-data/sda1]
root       662     2  0 Sep22 ?        00:00:00 [xfs-conv/sda1]
root       663     2  0 Sep22 ?        00:00:00 [xfs-cil/sda1]
root       664     2  0 Sep22 ?        00:00:00 [xfs-reclaim/sda]
root       665     2  0 Sep22 ?        00:00:00 [xfs-log/sda1]
root       666     2  0 Sep22 ?        00:00:00 [xfs-eofblocks/s]
root       667     2  0 Sep22 ?        00:00:00 [xfsaild/sda1]
root       672     2  0 Sep22 ?        00:00:00 [kdmflush]
root       673     2  0 Sep22 ?        00:00:00 [bioset]
root       680     2  0 Sep22 ?        00:00:00 [xfs-buf/dm-2]
root       681     2  0 Sep22 ?        00:00:00 [xfs-data/dm-2]
root       682     2  0 Sep22 ?        00:00:00 [xfs-conv/dm-2]
root       683     2  0 Sep22 ?        00:00:00 [xfs-cil/dm-2]
root       684     2  0 Sep22 ?        00:00:00 [xfs-reclaim/dm-]
root       685     2  0 Sep22 ?        00:00:00 [xfs-log/dm-2]
root       686     2  0 Sep22 ?        00:00:00 [xfs-eofblocks/d]
root       687     2  0 Sep22 ?        00:00:23 [xfsaild/dm-2]
root       704     1  0 Sep22 ?        00:00:05 /sbin/auditd -n
root       727     1  0 Sep22 ?        00:00:25 /usr/lib/systemd/systemd-logind
root       730     1  0 Sep22 ?        00:00:06 /usr/sbin/rsyslogd -n
root       732     1  0 Sep22 ?        00:00:04 /usr/sbin/irqbalance --foreground
dbus       733     1  0 Sep22 ?        00:01:02 /bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
root       824     1  0 Sep22 tty1     00:00:00 /sbin/agetty --noclear tty1 linux
apache     873 11687  0 12:18 ?        00:00:11 /usr/sbin/httpd -DFOREGROUND
root      1027     1  0 Sep22 ?        00:00:09 /usr/bin/python -Es /usr/sbin/tuned -l -P
root      1028     1  0 Sep22 ?        00:00:02 /usr/sbin/sshd -D
root      1505  1028  0 09:19 ?        00:00:00 sshd: root@pts/0
root      1676  1505  0 09:19 pts/0    00:00:00 -bash
root      1891     2  0 12:41 ?        00:00:00 [kworker/2:1]
root      2618     2  0 12:41 ?        00:00:00 [kworker/1:2]
polkitd   2898     1  0 Sep22 ?        00:00:16 /usr/lib/polkit-1/polkitd --no-debug
root      4516 11813  0 12:43 ?        00:00:00 /usr/sbin/CROND -n
root      4517 11813  0 12:43 ?        00:00:00 /usr/sbin/CROND -n
root      4518 11813  0 12:43 ?        00:00:00 /usr/sbin/CROND -n
root      4519 11813  0 12:43 ?        00:00:00 /usr/sbin/CROND -n
root      4520 11813  0 12:43 ?        00:00:00 /usr/sbin/CROND -n
nagios    4529  4520  0 12:43 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1
nagios    4530  4517  0 12:43 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1
nagios    4531  4519  0 12:43 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios    4532  4518  0 12:43 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1
nagios    4533  4531  0 12:43 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
nagios    4534  4529  0 12:43 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
nagios    4535  4530  0 12:43 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios    4539  4516  0 12:43 ?        00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1
nagios    4540  4532  0 12:43 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
nagios    4544  4539  0 12:43 ?        00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
root      4612     1  0 Sep22 ?        00:00:00 /usr/sbin/xinetd -stayalive -pidfile /var/run/xinetd.pid
root      4622     2  0 12:43 ?        00:00:00 [kworker/u64:0]
root      4906     2  0 10:28 ?        00:00:00 [kworker/1:3]
nagios    5279 17269  0 12:43 ?        00:00:00 /usr/bin/python /usr/local/nagios/libexec/check_bigip_tps.py -H 10.9.2.251 -C ITsnmp -T 500
root      5406  1676  0 12:43 pts/0    00:00:00 ps -ef --cols=300
root      6073     1  0 09:00 ?        00:00:06 /usr/sbin/veeamservice --daemonize --pidfile=/var/run/veeamservice.pid
ajaxterm  6112     1  0 Sep22 ?        00:00:22 python /usr/share/ajaxterm/ajaxterm.py --daemon --port=8022 --uid=ajaxterm
root      6510     2  0 09:00 ?        00:00:00 [kworker/3:0H]
apache    6554 11687  0 12:21 ?        00:00:09 /usr/sbin/httpd -DFOREGROUND
root      9728     2  0 12:24 ?        00:00:00 [kworker/0:2]
root      9748     2  0 12:24 ?        00:00:00 [kworker/3:3]
apache   10138 11687  0 12:02 ?        00:00:14 /usr/sbin/httpd -DFOREGROUND
root     10626     2  0 09:03 ?        00:00:00 [cifsiod]
root     10630     2  0 09:03 ?        00:00:01 [cifsd]
root     11687     1  0 Sep22 ?        00:00:06 /usr/sbin/httpd -DFOREGROUND
nagios   11719     1  0 Sep22 ?        00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios   11798     1  0 Sep22 ?        00:00:01 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
root     11813     1  0 Sep22 ?        00:00:03 /usr/sbin/crond -n
root     13842  1028  0 08:41 ?        00:00:00 sshd: root@notty
root     13851 13842  0 08:41 ?        00:00:00 /usr/libexec/openssh/sftp-server
apache   15036 11687  1 12:27 ?        00:00:10 /usr/sbin/httpd -DFOREGROUND
root     15655     2  0 11:21 ?        00:00:00 [kworker/1:0]
nagios   17263     1  0 06:52 ?        00:01:22 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios   17265 17263  0 06:52 ?        00:00:08 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   17266 17263  0 06:52 ?        00:00:08 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   17267 17263  0 06:52 ?        00:00:07 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   17268 17263  0 06:52 ?        00:00:08 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   17269 17263  0 06:52 ?        00:00:07 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   17270 17263  0 06:52 ?        00:00:08 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios   17274 11719  0 06:52 ?        00:00:15 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios   17275 17274  0 06:52 ?        00:02:54 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios   17330 17263  0 06:52 ?        00:00:01 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root     17735     2  0 12:29 ?        00:00:00 [kworker/3:0]
root     17810     2  0 09:08 ?        00:00:00 [bioset]
root     17811     2  0 09:08 ?        00:00:00 [bioset]
mysql    18299     1  0 Sep22 ?        00:00:00 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
mysql    18456 18299  1 Sep22 ?        00:26:32 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
apache   18822 11687  1 12:30 ?        00:00:08 /usr/sbin/httpd -DFOREGROUND
apache   19700 11687  1 12:30 ?        00:00:08 /usr/sbin/httpd -DFOREGROUND
root     20094     2  0 12:31 ?        00:00:00 [kworker/u64:2]
root     20982     2  0 09:10 ?        00:00:00 [kworker/2:2H]
root     21298     2  0 12:32 ?        00:00:00 [kworker/0:0]
root     23622     2  0 Sep22 ?        00:00:00 [kworker/2:0H]
root     24959     2  0 11:50 ?        00:00:00 [kworker/2:2]
apache   25918 11687  1 12:35 ?        00:00:05 /usr/sbin/httpd -DFOREGROUND
root     25975     2  0 12:35 ?        00:00:00 [kworker/2:0]
root     27775     2  0 12:36 ?        00:00:00 [kworker/1:1]
apache   28145 11687  1 12:36 ?        00:00:04 /usr/sbin/httpd -DFOREGROUND
apache   29207 11687  1 12:37 ?        00:00:05 /usr/sbin/httpd -DFOREGROUND
root     29795     2  0 12:38 ?        00:00:00 [kworker/3:1]
root     29814     2  0 12:38 ?        00:00:00 [kworker/u64:1]
root     30718     2  0 Sep22 ?        00:00:01 [kworker/3:2H]
root     31483     2  0 12:39 ?        00:00:00 [kworker/0:1]
apache   31719 11687  0 12:16 ?        00:00:11 /usr/sbin/httpd -DFOREGROUND
[root@nagios ~]# tail -50 /usr/local/nagios/var/perfdata.log
tail: cannot open ‘/usr/local/nagios/var/perfdata.log’ for reading: No such file or directory
The missing perfdata.log file isn't good.
Can you post the following files?
/usr/local/nagios/etc/pnp/process_perfdata.cfg
Also, run the following and post the output?
ls -l /usr/local/nagios
ls -l /usr/local/nagios/var
jpipitone
Post by jpipitone »
nagios.cfg
[root@nagios ~]# ls -l /usr/local/nagios
total 28
drwxrwxr-x.  2 nagios nagios 4096 Sep 22 10:47 bin
drwsrwsr-x.  8 apache nagios 4096 Sep 22 19:45 etc
drwxr-xr-x.  2 root   root      6 Sep 22 10:47 include
drwxrwsr-x.  2 nagios nagios 4096 Sep 22 13:00 libexec
drwxrwxr-x.  2 nagios nagios 4096 Sep 22 10:46 sbin
drwxrwxr-x. 18 nagios nagios 4096 Sep 22 10:47 share
drwxrwxr-x.  6 nagios nagios 4096 Sep 23 13:32 var
[root@nagios ~]# ls -l /usr/local/nagios/var
total 239432
drwxrwxr-x. 2 nagios nagios        37 Sep 22 23:59 archives
-rw-r--r--. 1 nagios nagios  29768405 Sep 23 13:32 host-perfdata
-rw-r--r--. 1 nagios nagios        34 Sep 23 10:52 nagios.configtest
-rw-r--r--. 1 nagios nagios         6 Sep 23 06:52 nagios.lock
-rw-r--r--. 1 nagios nagios    430618 Sep 23 13:30 nagios.log
-rw-r--r--. 1 nagios nagios         6 Sep 22 10:50 ndo2db.lock
-rw-r--r--. 1 nagios nagios         0 Sep 23 06:52 ndomod.tmp
srwxr-xr-x. 1 nagios nagios         0 Sep 22 10:50 ndo.sock
-rw-r--r--. 1 nagios nagios       235 Sep 22 10:50 npcd.log
-rw-r--r--. 1 nagios nagios   1430373 Sep 23 06:52 objects.cache
-rw-r--r--. 1 nagios nagios   1430373 Sep 23 10:52 objects.precache
-rw-------. 1 nagios nagios   2210861 Sep 23 12:52 retention.dat
drwxrwsr-x. 2 nagios nagcmd        39 Sep 23 06:52 rw
-rw-r--r--. 1 nagios nagios 144893839 Sep 23 13:32 service-perfdata
drwxr-xr-x. 5 nagios nagios        52 Sep 22 10:46 spool
drwxr-xr-x. 2 nagios nagios        21 Sep 22 12:43 stats
-rw-rw-r--. 1 nagios nagios   2202337 Sep 23 13:32 status.dat
It looks like the performance graphs haven't been working for a while and the size of the old data is quite large so it will have to be deleted.
To do that, login as root to the XI server and run the following.
> /usr/local/nagios/var/host-perfdata
> /usr/local/nagios/var/service-perfdata
Next, lets restart the daemons that process that data.
service crond stop
service npcd stop
service nagios stop
service crond start
service npcd start
service nagios start
If all goes well, the graphs should start to populate after 15 minutes.
If not, can you email in this file
/usr/local/nagios/etc/commands.cfg
And, run this and post the output.
ps -ef --cols=300
jpipitone
Post by jpipitone »
I've removed both of those files, but still no luck.
commands.cfg attached
Output attached.
output.txt
output2.txt
commands.cfg
It looks like at one time, the system had a ran disk setup on it at one time and some of the settings, not all, were reverted back and that is causing the issue.
You may want to look at this document for the instructions on setting up a ramdisk and update the missing information and see if that fixes the issue for you.
https://assets.nagios.com/downloads/nag ... giosXI.pdf
jpipitone
Post by jpipitone »
That sounds about right - we had a RAM disk before. I don't plan on using the RAM disk again, now that we're 64 bit, it is running great.
I'll make the adjustments and get back to you. Thanks
Your welcome. Let us know if you get it fixed.
