Nagios XI Monitoring Engine refuses to start
gryph0n
Post by gryph0n »
Operating System = CentOS 7.2.1511 (core)
Running virtual (Hyper V)
Nagios Version: 4.0.8
Nagios Plugins: 2.0.3
64-bit systems
I rebooted the server and the dashboard shows that the Monitoring Engine is off and it will not start. On the server, Nagios is running, but with errors. Screenshots of both attached.
The research that I've done has not provided many results at all. If anyone could provide some input, I would greatly appreciate it.
Thank you.
Re: Nagios XI Monitoring Engine refuses to start
Can you login to the server as root, run the following to see is the nagios daemon starts.
service nagios stop
killall -9 nagios
service nagios start
If this still fails, please run the following and post the output.
ps -ef --cols=300
df -h
df -i
