Linux Distro: CentOS release 6.8 (final)
64-bit image
Hyper-V install (preconfigured Hyper-V image downloaded from Nagios)
No proxies etc
Bit of backstory (initial problem):
I first installed my own OS (CentOS (core/minimal) / 64 bit / Hyper V). Installed Nagios following the instructions provided to the letter. Was able to open up my web portal and see the dashboard etc. When I was trying to connect to a Windows server, it flat out refused. I banged away at different solutions off and on for a week. I finally threw the towel in and figured I must have dome something wrong that just hosed the entire image. No big, I felt like it was a positive learning experience. I fiddled with the NSClient, the server, firewalls, virtual switches, plugins, etc. Basically everything I could find on the web that may have mentioned a possible issue, I explored. I kept getting the same error over and over:
The odd thing is, no matter the name of the server I was trying to connect to, it kept referring to the same server name (pulling some bad meta-data from somewhere?) If I were trying to connect to a DC, it filled in the print server. WSUS...print server. I looked at the .cfg files and it says that manually editing them will do no good. I tried anyway, for good measure. Same issue (of course). I'm new to this environment and have no documentation on the servers, networking, or hyper v configs. I try to narrow it down between server/client/networking/hyper-v/etc.Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/servername.com.local.cfg', starting on line 16)
Second Fresh Install: Preconfigured Nagios Hyper-V image
I follow the instructions for importing the image to Hyper-V verbatim. No issues. As a test server, I hit the primary DC. Bang! no problems. GREAT! So I though...I hit the print server again, and same exact error as before. Now I try another server, and it refuses to connect again. Same issue as the first time, it pulls the same exact error pointing to the configs for the print server, even though I'm NOT trying to connect to the print server.
I've even renamed the original print server config files to .old and deleted the .cfg and tried to connect to something other than the print server. Same exact error, and pulling the print server name...AGAIN.
So this error has happened in the exact same fashion on two different machines. On my initial install, I did try the DC first, and it did connect. After getting this series of errors (that all seem to stem from trying to connect to the print server) on both instances, I'm at a dead end.
So if you're still with me, and had the patience to read through all this..
Help me Obi Wan...you're my only hope.
