Nagios ramdisk checks
benhank
Post by benhank »
Hey guys!
I just installed a ramdisk on my xi5 systems. Are there any checks or plugins out there that monitor the ramdisk? I looked in the exchange but I cant find any.
Reason: marking with green check mark
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: Nagios ramdisk checks
There aren't, you could probably just use the check_disk check to specify the path for it though and go that route.
If not just the capacity, what metrics are you looking to monitor in it?
benhank
Post by benhank »
well this turned out to be a timely post. I assigned 1.5 gb of space to the ramdisk but according to the syslog its out of space!
The metrics I am looking for would include capacity, and to see if it is running or if there are any errors, hung files the normal disk stuff you would want to keep an eye on.
Should I make a seperate post for the out of space issue?
the errors are:
Error: Unable to update status data file '/var/nagiosramdisk/status.dat': No space left on device
there are more erros but this is the gist of it.
Proudly running:
Nagios Fusion
ssax
Dreams In Code
Post by ssax »
You should just be able to use the standard linux disk checks to check them.
Try to find what files are filling it up and we can troubleshoot from there.
Thank you
When you run the check_disk command
/usr/local/nagios/libexec/check_disk -w 20 -c 10 -p /var/nagiosramdisk/
You get this output, is this what you are looking for?
DISK OK - free space: /var/nagiosramdisk 108 MB (99% inode=99%);| /var/nagiosramdisk=1MB;90;100;0;110
benhank
Post by benhank »
that works. you can lock this up, since the ramdisk is full and causeing me other issues i have to start a new thread.
Proudly running:
Nagios Fusion
Post by dwhitfield »
Glad to hear this particular issue is resolved. I am going to lock the thread. Thank you for using the Nagios forums!
